Pipe Insulation in Grill
Old Mar 17, 2008 | 12:32 AM
  #31
Lori's Avatar
Default Re: Pipe Insulation in Grill
MSantos, thanks for you recommendation! I blocked the two bottom rows. The coolant temperature seems to rise a bit faster than before, but it still never got higher than 80C. I'm just used to higher coolant temps from my previous car (Subaru). It went up to 90C on my 45min commute even when outside temperature was around -10C.
I have already seen some improvement in the fuel economy after installing the insulation!
Cheers,
Lori
Old Mar 17, 2008 | 08:16 AM
  #32
Lori, your Subaru probably had a 90c thermostat in the cooling system and your HCH2 is more than likely using a 80c thermostat. Maybe we should be installing hotter thermostats in our HCH2's? Something to consider for next winter. Cheers, H
Old Jan 16, 2009 | 08:33 AM
  #33
bochnak's Avatar
What size insulation? Looks like it's for 3/4" pipe?
Old Jan 16, 2009 | 08:49 AM
  #34
The bottom grill needs the one you mentioned and the upper needs a lgr. one.H
Old Dec 17, 2011 | 05:57 PM
  #35
06hch2's Avatar
F**k ExxonMobil
So 194 F is the maximum coolant temp. What about intake temp?
rperla
Jul 16, 2020 08:12 PM
kklein
Dec 23, 2009 04:52 AM
centrider
Apr 26, 2008 06:59 PM
KimikoPi
Feb 27, 2008 08:29 PM
mikieboyblue
Mar 21, 2007 05:14 PM
