Navigation never goes "dark"
According to my manual, the Navigation map color should switch to the default "night" color when the headlights are on. But my map color stays at the daytime color 24/7. I have different colors specified for Day and Night mode, and the preference in my Setup commands is "Auto", meaning it should switch automatically.
Anything else I can try?
Re: Navigation never goes "dark"
Yawn ... Try setting your dash lights to a lower setting. There are separate settings for when the headlights are on and one for when the headlights are off.
Well I don't have my Civic yet but on my Acura if you have the dash lights set at full brightness, the NAVI will never dim. You may want to check that and reduce the brightness of the dash lights.
I had the same problem with the Nav never going to night mode. Then I read the comment about dimming the instrument panel to less than max brightness. The Nav still wouldn't go to night mode. Then after trying it a few more times the problem went away. I may have adjusted the instrument panel brightness in day mode (with headlights off) the first time.
As others have noted, I wish Honda's software engineers would stop trying to prove how clever they can make the car and let me think for myself.
Originally Posted by ElanC
Ah, you may have solved my mystery.
drquine
06-23-2006 05:41 PM
adjust, auto, brightness, civic, color, dark, day, headlights, highlander, honda, instrument, map, nav, navigation, night, panel, toyota
