Improving Ride Comfort
Old Sep 27, 2005 | 09:34 AM
ovni's Avatar
Default Improving Ride Comfort
I just bought a used 2003 Civic Hybrid. It needed new tires so I boguth a set of Goodyear Comfotred. They are very quiet and comfortable. Anyway I can make the ride better. i dont want to bring my tire psi below 40. Any good after market springs out there?
Old Sep 27, 2005 | 09:41 AM
livvie's Avatar
Default Re: Improving Ride Comfort
how about you buy some of that tempur material and make a seat cushion out of it.
Old Sep 27, 2005 | 10:04 AM
phoebeisis's Avatar
MPG FANATIC WITH GUZZLERS
Default Re:Springs usually stiffer-expensive shocks-struts maybe
You won't have any luck finding softer spring rate springs;most aftermarket springs are stiffer,or worse-stiffer and shorter for drops.You have 2 options
1)Hunt up some adj shocks-struts-.that have compression and rebound damping.There is a tiny chance that you will find some struts(or whatever they call you shock-spring combo) with some preload adj.You might be able to make some hay with the preload adj,but usually it won't help harshness.Look for adj shocks that advertise"soft ride".Most aftermarket shocks with adj features are performance shocks-read stiff!
2)Drop your tire pressure to "stock".It will make a noticeable improvement and will cost maybe 1 mpg(2%),if that.
The tire pressure adj is free-shocks-struts-springs are deep in the $100's.$300 is 100 gallons- at 44 mpg vs 45 mpg -$3/gal it will take 200,000 miles to make up the $300 gallons.Luck,Charlie
Old Sep 27, 2005 | 10:06 AM
lars-ss's Avatar
Could you specify exactly what piece of the ride comfort is lacking? If the car too stiff, too bouncy, too much road feel in the steering, too cushy?
I have a 2004 HCH and even with the tires at 52 PSI, the ride is fine and I don't notice any discomfort in any way......
I guess I'm just confused as to what part of the ride comfort is not comfortable?
Old Sep 27, 2005 | 03:05 PM
bigbearballs's Avatar
52psi, holy crap!
Old Sep 29, 2005 | 08:24 AM
ovni's Avatar
I went to walmart and found a memory foam seat cover. I also lowered my psi to 35. Ride feels better.
Old Sep 29, 2005 | 09:06 AM
philmcneal's Avatar
04 prius 350,000km
Originally Posted by bigbearballs
52psi, holy crap!
that's what i said too... i remember my friend's tire was so overflated he pulled over. As soon as he did the left front tire blew up causing a crack through the body!!!!
Hope that doesn't happen to you
Old Sep 29, 2005 | 09:39 AM
lars-ss's Avatar
Actually, UNDER inflation is FAR more likely to cause blowouts. Wayne (xcel) convinced me that higher inflation is perfectly safe and workable, and usually does not lessen or negatively affect tire wear or performance.
Search this site for more discussions on this subject....
Old Sep 29, 2005 | 10:29 AM
xcel's Avatar
Hi Philmcneal:
___Burst pressures for today’s tires are in the 125 - 150 # range, not 60 #’s and below.
___Good Luck
___Wayne R. Gerdes
___Waynegerdes@earthlink.net
ConchDiesel
Jun 14, 2014 01:34 PM
clostridium
Mar 20, 2007 11:26 AM
Latanagourds
Sep 12, 2006 05:32 PM
mr_132
Aug 31, 2006 08:59 AM
bluesesshomaru17
Jan 5, 2006 04:35 PM
