IMA/Check Engine Light HELP!
Old Aug 11, 2007 | 04:57 PM
troubled HCH owner's Avatar
Default Re: IMA/Check Engine Light HELP!
Thanks DougD! That's helpful to know. FYI--I'm still waiting for Honda to get back to me about helping me out.
Old Aug 19, 2007 | 08:52 PM
Just wanted to let everyone know: Honda came through!!!!! They replaced the IMA battery at no charge even though it's not under warranty anymore. Thank you so much for the suggestion!!!
Old Aug 26, 2007 | 02:34 PM
gumby's Avatar
Energy Independence
Very nice. Glad Honda came through. I think they are well aware of some issues with the 2003 model.
Old Aug 26, 2007 | 05:08 PM
It must feel like a new car, I'll bet!
Old Aug 27, 2007 | 01:44 PM
It does run better, but suprisingly not THAT much better. I'm in Las Vegas though, where the temperatures are always over 100. I think that makes a difference.
Old Sep 10, 2007 | 08:23 AM
raidfibre's Avatar
Temperature definitely makes a difference!
NiMH batteries get hot as they are charged anyway, and when in the heat things get even worse.
Admittedly I don't know a lot about the HCH specifically, but I know that other (larger) NiMH packs require active cooling to stay within a temperate range.
The GM EV-1 (may it rest in peace) ran the A/C while charging, if the temperature was too high. I'm just using this as an example. The HCH battery is only a fraction of the size, but the same principles apply.
M
stoshiro
Jan 12, 2021 03:11 PM
cak615
Oct 28, 2013 08:11 PM
cazort
Oct 28, 2013 08:07 PM
funnd
Aug 1, 2012 12:23 PM
SadCarTime
Jul 9, 2012 08:05 AM
