how does MPG gauge work?
Old Nov 15, 2005 | 05:58 AM
laurie's Avatar
my other car is a FJORD
Question how does MPG gauge work?
i mean, not literally how does it go up and down LOL......what is the output based on? combination of speed, pedal pressure, etc? i am somewhat technically challenged here, but would like to know.
thanks
Old Nov 15, 2005 | 06:26 AM
gonavy's Avatar
Default Re: how does MPG gauge work?
The engine computer knows how much fuel it has metered into the cylinders (electronic fuel injection), and it knows how far you've travelled from the odometer. Those parameters are all part of the standardized OBD2 engine diagnostics protocol.
It determines how much fuel to meter based on current speed, throttle position, rpm/gear, air temp & pressure, and type of fuel.
Old Nov 15, 2005 | 09:15 AM
phoebeisis's Avatar
MPG FANATIC WITH GUZZLERS
Default Re:Knows speed-knows fuel flow-
The ECU knows your speed in MPH,and it knows the fuel flow in gallons per hr .60m/h/3 g/h=20 m/g Luck,Charlie there is a flowmeter in there somewhere-or an indirect flowmeter based on the pressure and number of squirts, duration of squirts of the Fuel injectors(or fuel pump).Luck,Charlie
EatingPie
Dec 10, 2007 04:09 PM
TOHHybrid
Aug 1, 2006 03:25 PM
jnr
May 14, 2005 11:21 AM
Dale B
Apr 10, 2005 10:03 AM
Hot_Georgia_2004
Jul 2, 2004 03:21 PM
