Honda says HCH II's wheel weight is proprietary
Old Aug 15, 2007 | 12:16 PM
owlmaster08's Avatar
Default Re: Honda says HCH II's wheel weight is proprietary
A weight being proprietary? You should have told her that she might as well tell you because you were going to find out either the easy way or the hard way. I wonder what response that would have generated.
Old Aug 15, 2007 | 05:26 PM
OlympicDreams's Avatar
iautobodyparts.com thinks that they are 20 lbs each.
http://shop.iautobodyparts.com/37306...loy_wheel.html
Old Aug 19, 2007 | 07:57 PM
Wheel is 16 lbs. and tire is 19 lbs.
Old Aug 22, 2007 | 10:17 PM
Rick's Avatar
If you want some light weight wheels check out the Kosei K1-TS on Tire rack. I have a set of these 15's on my 92 Saturn SC electric conversion and I shaved 8 lbs of rotating wheel per corner. The 15's are 12.6 lbs each! It made a big difference in acceleration power required. They are a bit wider, but the existing tires should fit just fine.
Curated Content Editor
Dec 27, 2013 07:20 AM
civicnleo
Dec 21, 2011 09:09 PM
UWAdventurer
Jul 8, 2008 04:50 AM
fastducatirider
Jan 3, 2006 11:56 AM
sirlan
Aug 4, 2004 07:18 PM
