HCH Modifications
Old Mar 31, 2004 | 04:20 PM
Hot_Georgia_2004's Avatar
I started this thread to find out what modifications are being done on the HCH.
The only thing I've done is to get the car up off of it's "flat" tires.
Honda's door sticker suggests 30 F/R.
This is like trying to ride a bicicle on a soft sandy beach. Boardwalk is much easier!
The sidewall on my Dunlops are rated at 51PSI and that's where I keep them.
While the safety margin is reduced due to less patch, my slower speeds are an offset. My driving style rarely exceeds 62MPH.
To be sure I did a test in a mall parking lot in the pouring rain @ 50MPH:
40PSI VS 51PSI and stopping difference between the two figures were only a few feet.
Did not notice any difference in a swerve/skid test, although this is harder to measure.
The difference in mileage gained from 30PSI to 51PSI is about 20MPG.
If you should decide to try this be aware that the car will ride alot stiffer (But better handling) and will not stop as fast. At 6K miles I haven't noticed any unusual tire wear. In my case the dealer tossed new tires for life.
Your tires might be rated differently.
What mods have you done to YOUR HCH?
Steve
Old Mar 31, 2004 | 07:55 PM
Stevo12886's Avatar
wait...your run it at 51psi cold or hot (after or before any driving), the psi goes up 4 when you drive.
Old Mar 31, 2004 | 08:17 PM
51PSI while the tires are stone cold.
Steve
Old Apr 1, 2004 | 01:41 PM
Stevo12886's Avatar
ooo, measure them imediatly after you stop..it probably exceeds the sidewall limit.
Old Apr 1, 2004 | 07:51 PM
Thanks stevo12886.
51PSI is the cold inflation rating.
Steve
Old Apr 1, 2004 | 08:43 PM
Stevo12886's Avatar
cool, maybe i can put a full 44psi in my HydroEdge tires
Old Apr 1, 2004 | 09:10 PM
For the last 20 years or so I've ran ALL my vehicles tires up to the sidewall
cold PSI limit. I forgot the brand our Grand Caravan uses, basically a truck
tire rated at 44PSI MAX COLD. All are inflated to 44.
Old Apr 5, 2004 | 09:55 AM
jjmcubed's Avatar
Run my HCH at 51psi cold. I also removed my front plate. Hopefully I won't get pulled over for it.
Old Apr 5, 2004 | 12:34 PM
Jason's Avatar
Site Founder
OFFTOPIC ALERT Shall I split the topic?
Old Apr 13, 2004 | 06:51 AM
sirlan's Avatar
I removed the front plate and will be getting my windows tinted this weekend. That's all I can think of right now.
