Harman-Kardon Ipod interface
Old Nov 20, 2005 | 05:17 PM
clayk's Avatar
Default Harman-Kardon Ipod interface
I just had the Harman-Kardon Drive+Play iPod adapter installed in my 05HCH. I put the LCD on the dash to the left of the steering wheel next to the pillar, and the jog wheel below the center armrest. This setup is just terrific. You cab easily see the menus without taking your eyes off of the road. The jog wheel is very similar to the ipod controls. It is very intuitive and easy to use. far safer than fumbling with the ipod while driving and much better interface than the built in iPod support my aftermarket headunit (Kenwood).
Anyone thinking about adding iPod connectivity to their car should at least take a look.
Clay
Old Nov 20, 2005 | 05:56 PM
IndyDoug's Avatar
Default Re: Harman-Kardon Ipod interface
This is on my wishlist. Anyone know how the FM transmitter sounds?
Old Nov 20, 2005 | 08:07 PM
Civic Duty's Avatar
Brains of the Operation
I tried using a seperate FM transmitter for my iPod, and I just put my iPod in the cupholder. However, the sound quality wasn't all that great. Is this solution FM-transmitter based, or is there some way to wire it into the audio system?
Old Nov 21, 2005 | 06:26 AM
clayk's Avatar
The Drive+play can be used wire directly into the head unit, or FM modulation. I believe (but not positive) that you can get an adapter that lets you plug it directly into the cd changer port. I was told this by the stereo shop and they actually showed me the adapter hanging on a rack, but I do not remeber the name. I believe it has been mentioned on this board before.
You also have the option of the "direct wired" FM modulation. This is where you take a splitter that puts the unit in-line with your antenna. I did this with an XM radio on another car and it had much higher quality than using FM the traditional way
spiff72
May 4, 2008 08:49 AM
cherokee180c
Jul 21, 2006 09:26 AM
CrossroadsKid
Jun 5, 2006 11:30 AM
InaTcup
Aug 15, 2005 07:42 AM
