Electric Motor - HCH-II vs. Prius
Old Apr 21, 2006 | 09:33 AM
NovaScotian's Avatar
Default Electric Motor - HCH-II vs. Prius
I just heard, from a Honda "Salesman" If the Prius electric motor fails, the car is inoperative till repaired. The advantage to Honda's Hybrid is if the electric motor fails, you can still operate the car on the gas engine alone.
Is it true the Prius will not run on the engine if the electric motor stops working?
Old Apr 21, 2006 | 09:41 AM
Double-Trinity's Avatar
Default Re: Electric Motor - HCH-II vs. Prius
This is true as the electric motor (actually, two electric motors) in the Prius are required for the transmission to function. The Prius tranmission is essentially a single gear system. In high gear, it simply tranmsits the engine power mechanically. However, In order to get torque for "low gearing", it must convert some of the engine's mechanical power into electrical, with one motor acting as a generator powering the other. This must happen even if there is no flow of power into or out of the battery. This is also the reasno why the Toyota Hybrid System won't work for off-road driving, where slippy conditons can damage the motors, a true mechanical tranmission would be needed.
That's not to say the Toyota Hybrid System isn't without its advantages, it has plenty, including reliability advantages and huge efficiency advantages in city driving conditions.
Old Apr 21, 2006 | 09:54 AM
bilbro's Avatar
It would seem to me that of all the things that could go wrong with a hybrid, the electric motor failing should be fairly rare; not something I'd loose much sleep over.
Old Apr 21, 2006 | 01:10 PM
AZMerf's Avatar
Supposedly, if the battery fails or doesn't have a charge too.
Old Apr 21, 2006 | 02:23 PM
lifespeed's Avatar
[QUOTE=Double-Trinity]This is true as the electric motor (actually, two electric motors) in the Prius are required for the transmission to function. The Prius tranmission is essentially a single gear system. In high gear, it simply tranmsits the engine power mechanically. However, In order to get torque for "low gearing", it must convert some of the engine's mechanical power into electrical, with one motor acting as a generator powering the other. This must happen even if there is no flow of power into or out of the battery. This is also the reasno why the Toyota Hybrid System won't work for off-road driving, where slippy conditons can damage the motors, a true mechanical tranmission would be needed.QUOTE]
My understanding is that the Prius uses a CVT transmission.
You can't get added torque from an engine turning at a low speed by placing more load on it to turn a generator to turn an electric motor. If you disconnect the engine from the trans and use it to supply electricity to turn an emotor, your acceleration is then limited to the emotor's modest horsepower.
Old Apr 21, 2006 | 07:08 PM
nbalthaser's Avatar
the prius does employ a continuously variable transmission. the difference is that it uses a planetary gear system versus the civic's belt and pulley system. two very different systems but both are continously variable.
Old Apr 21, 2006 | 08:04 PM
The system uses a a sun-and-planet gearset to split the engine's load between a mechanical connection, and a generator, which converts those extra RPMs into electric current. The engine is never disconnected from the transmission.
This site explains how it works, here's an excerpt:
Always in Top Gear
We have discovered above how the Prius transmission uses an epicyclic gear, a generator and control electronics to adjust the spin rate of the engine without the use of either a step transmission or a conventional CVT. We also discovered that a fixed proportion (about 72%) of the ICE torque is sent mechanically to the wheels. Without the ability to change the gear ratio between the ICE and the wheels, we cannot multiply up the ICE torque to get high acceleration at low speed. Although we've solved the problem of letting the ICE spin at a suitable rate when the car is moving slowly, the torque coupling is equivalent to always being in top gear!
This problem is partly solved already by passing generated electricity from MG1 to MG2 which adds its torque to that of the ICE. Electric motors do not share with an ICE the problem of not generating torque at low speed. In fact, this is where they generate the most torque. If we run the ICE at, say, 2000 r.p.m., with the car barely moving, a lot of power passes from the ICE to MG1. In fact, until the car starts moving, all the power goes to MG1. Even though MG1 gets only 28% of the torque, it gets all of the movement! Since MG2, connected to the wheels, is not rotating very fast, it doesn't take much power to generate its maximum torque. The Prius can launch from a standstill at respectable acceleration up to about 15 k.p.h. using ICE power passing primarily through MG1 and MG2. Only about a fifth of the torque comes directly through the mechanical path during this initial acceleration.
Though this system could run without battery power theoretically, it can't start if the high voltage battery pack is dead, since it uses one of the motors to start the engine. It doesn't have a backup starter like the Hondas do, and I dont believe there's any convenient place to attach one. However, this is not a mechanical CVT, as it never changes the actual gear ratios at all, it simply "blends" the torque between the directly mechanical, and the electrical pathways.
Also, the fact that this system cannot run wihtout electric motors is relevent, even though electric motors are likely the last thing that will fail in normal driving -- the electric motors run the risk of overheating in offroad situations where they have a chance of being stuck in the mud for example. While this would not be a problem for a normal car, it could fry an electric motor trying to produce all that torque. That's why you won't be seeing any offroad-capable hybrid trucks using Toyota's system. However, Honda's system would potneitally work in a truck for going offroad as even without electric motors running, it can gear down the engine.
Old Apr 21, 2006 | 09:08 PM
CamelFilters's Avatar
I think i bought the wrong car,
someone help me out, i live a very dense and populated city with excellent roads but i work up on top of a really high and muddy mountain.
do i run a risk of destroying my electric motor?
would it help if i had bought a tank instead?
Old Apr 22, 2006 | 08:33 AM
toast64's Avatar
Nah, you're okay. Essential tools for your commute, though: 1. Cell phone with towing company on speed dial. 2. Cooler with six-pack while waiting for tow truck...
Old Apr 22, 2006 | 11:56 AM
Cool
I was going to go out and trade my Prius for a Hummer
Or better yet, i'll just go capture one of those mountain goats and ride on their backs all the way up the mountain.
rodval
Oct 30, 2006 05:02 PM
manchild
Aug 23, 2006 11:42 AM
spiff72
Aug 11, 2006 12:06 PM
marlon
Aug 8, 2006 08:54 PM
flare
Apr 19, 2004 07:18 PM
