Civic Hybrid Performance
Old Sep 13, 2007 | 11:47 AM
vbpdaddy's Avatar
Default Civic Hybrid Performance
My dealer thinks I'm nuts. When I took my 06 civic hybrid in for it's 1st oil change I commented that it was "lurching" a lot. As a result they replaced the transmission. Now, my MPG never exceeds 35 MPG, regardless of driving conditions. Previously, I would get between 42-47MPG on a regular basis.
I brought this to the dealer's attention and they claimed the computer is off and that the mileage is fine. In addition, I've noticed that my tach nearly redlines when pulling out at a light. I've actually been at 5500 rpm going 35 mph. I'm wondering if this is normal or if I should pursue. Could the two be related? The challange is getting the dealer to take me seriously.
One last observation. I've had a lot of paint discoloration on the hood and front bumper. I'm told this is due to bird droppings and, as such, not covered. Anyone else having paint issues? Thanks.
Old Sep 13, 2007 | 12:18 PM
noflash's Avatar
Default Re: Civic Hybrid Performance
Hmmm... time for a new dealer.
I wish you the best of luck.
Old Sep 13, 2007 | 12:30 PM
msantos's Avatar
Eco Accelerometrist
noflash is absolutely right.
Your problems are not normal and I suspect the earlier transmission replacement may have not been necessary at all. Sadly this stuff is symptomatic of dealerships who are behind in their "technician training obligations" and may even be lacking the appropriate resources and materials.
I fear the dealer you are dealing is clearly not willing and able to look at your issue properly. Please do yourself a favor and see another dealership.
Cheers;
MSantos
Old Sep 13, 2007 | 07:37 PM
giantquesadilla's Avatar
Yah. Find a new dealer.
Old Sep 14, 2007 | 09:46 AM
vincep5's Avatar
why would someone already replace the transmission within the first oil change...Theres something really wrong here. Is this your first hybrid?
Old Sep 14, 2007 | 03:28 PM
privatejoker's Avatar
Go over their heads, Honda needs to know about that kind of customer service.
Old Sep 14, 2007 | 09:31 PM
gumby's Avatar
Energy Independence
First - Are you actually CALCULATING your MPG (by dividing actual miles driven by actual gallons used), or are you just going by what the car's display says? Calculate it. Then, if the MPG IS 35 (and your driving habits & conditions have not changed), either the speedometer/odometer is severely off (doubtful) or there is a serious problem with their tranny "repair". You've removed the "computer" from the equation this way.
Another way to check your speedometer/odometer accuracy is to hit the interstate. Note a mile marker, and note your odometer (miles) at the moment you pass this mile marker. Drive until you cross a mile marker 10 miles away, and note your odometer (miles) at the moment you pass this (10 mile away) mile marker. Your odometer should be really close to exactly 10 miles higher.
IF the odometer is significantly off, then maybe the dealer is "sort of" right. Even so, I'd find another shop, because they should ALREADY be repairing your car - finding and curing this issue - whether it's the odometer, the "new" tranny, or the "computer."
Old Sep 19, 2007 | 05:57 PM
PapaMile's Avatar
For my daughter
Originally Posted by vincep5
why would someone already replace the transmission within the first oil change...Theres something really wrong here...
Well, if he change oil only every 300,000 miles, that might be normal.
PM
GreenBoy
Jul 22, 2010 01:48 AM
Jason
Hybrid & Related News
40
Aug 18, 2005 03:04 PM
Jason
Mar 30, 2005 03:43 PM
