Civic hybrid 06 driving technic summary thread
Old Dec 15, 2005 | 05:47 PM
  #101
slajeune's Avatar
Default Re: Civic hybrid 06 driving technic summary thread
What do you all think, should I leave the pulse and glide technique in the document? I think that one of the fundemental aspects to learn how to drive a hybrid is to learn how to coast / glide. This is one of the many differences between a normal car and a hybrid. While this technique also works on a conventional car, the hyrid is engineered (or so it seems) for this! This is why this is the first technique that every new owner of a hybrid should be aware and hence, it's inclusion in the document. While gliding, you will loose speed (either true regen or simply, physics). You will then have to speed up again. This is a very simple pulse and glide and one that even my mother could understand and execute.
Thanks,
Stephane.
Old Dec 15, 2005 | 05:59 PM
  #102
lakedude's Avatar
What method of gliding are you using? Does the 2006 shut itself off automatically during a glide? Dang, I need to go check out one of those new HCHs....but what if I end up wanting one?
Old Dec 15, 2005 | 06:01 PM
  #103
CGameProgrammer's Avatar
Originally Posted by xcel
___Actually, the AH is worth about 2 - 3 MORE mpg’s then the non-hybrid Accord just like the EPA shows …
I was being sarcastic. I was trying to indicate how much driving strategy matters even with non-hybrids, or perhaps especially with non-hybrids.
San Francisco was only a SOB when in and amongst the stop lights. The hills were not bad (although they were awfully steep) because of the gain down the back sides but the lights were murder.
It was the lights I was referring to, yeah. That and traffic. Stopping, which precedes accelerating, is what kills me, not going uphill.
___If I get out there next summer, Blue, NASA, yourself, and I are going to have a hypermiling clinic. That is about the only way I can cure you of a few habits that may be holding you and your HCH-II back! Those 80 mph jaunts are not helping but that inner city stuff? We can do a lot of things with that.
I think I'd be terrified. Still, it could be fun. I'll never change my highway habits but I'd be interested in seeing how you deal with city traffic.
Old Dec 15, 2005 | 06:04 PM
  #104
slajeune's Avatar
Hi Lakedude,
- When your are rolling at a desired speed remove your foot from the gas pedal
- Wait until your Instantaneous (current) Fuel Consumption Display maxes out to 100 miles per gallons (or goes down to 0 liters / 100km) and that you see some regeneration (green lines on your ASST / CHRG display)
- Very gently press on the gas pedal. Your aim is to eliminate the regeneration and (if possible) get a few lines of assist (1-4 lines of ASST)
- Let yourself glide! Please note that while gliding, you will gradually slow down.
This is what I am refering to. Yes, when you get the hang of it (actually, youjust have to remove your foot from the gas!), the engine stops using gas. It still turns, but it isn't burning any gas.
You don't want one, you NEED one
Cheers,
Stephane.
Old Dec 15, 2005 | 06:06 PM
  #105
NASAgineer's Avatar
I agree, especially with the 06 and the fuel shutoff/valves sealed glide with the option for EV.
Old Dec 15, 2005 | 06:08 PM
  #106
NASAgineer's Avatar
You might ammend that to say if the I-FCD drops below 100 MPG, you went too far. There's a fine line in terms of accelerator pressure between gliding w/o regen and turning the ICE back on.
Old Dec 15, 2005 | 06:18 PM
  #107
slajeune's Avatar
Hi NASA,
very good point.
Thanks,
Stephane.
Old Dec 15, 2005 | 09:32 PM
  #108
chesleyn's Avatar
Help! I'm using the carpool lane to get to work these days and my mpgs have dropped considerably to 46 mpg. I'm doing about 65-70 in the heavy traffic areas and then exit the carpool in the light zones and stay around 65 on the freeway. Any suggestions? Below 65 and I will get major agressive drivers on my tail. I live in Southern California. We have a lot of idiots here.
Old Dec 15, 2005 | 09:38 PM
  #109
NASAgineer's Avatar
How fast were you driving before you got your stickers? How much slower is the traffic in the #2 lane in the heavy traffic areas?
I just got my stickers today and will try them out for the first time tomorrow. I'm hoping I can just jump in the HOV lane when traffic in the other lanes drops below my preferred speed, then drop back out when it lightens back up. We'll see how well that works!
Old Dec 15, 2005 | 09:54 PM
  #110
bluecivichybrid's Avatar
slajeune,
I was able to do some tests over 10 miles today regarding how many bars of assist to use in ev-mode p&g on the 06 hch
it depends on the amount of battery charge you have:
7-8 bars of battery charge: during glide mode, use anywhere between 0-5 bars of assist. Don't worry about the battery drain: you have plenty of battery charge to use.
5-6 bars of charge: during glide mode, use between 1-3 bars of assist. You don't want to keep draining the battery too much anymore. 5 bars of charge is the optimum level you settle at - reaching a balance between assist and regen during pulse and glide intervals so that your battery remains steady at 5 bars. This is a good equilibrium point, I found, where forced regen is at most 1 bar that hardly affects your FE.
0-4 bars of charge: don't enter glide mode until you get at least 5 bars of charge back again. During this state, there will be 3 or more bars of forced regen that impacts your FE significantly. You're better off holding your speed or doing some slight driving with the load. (let speed decrease 5-10 mph uphill, let speed increase 5-10 mph downhill by holding your throttle steady)
I also found that the HCH is excellent in the city - maintained 60.0 mpg using pulse from stoplights and ev-mode gliding/braking in heavy traffic.
