civic 2008 charging issue help
Old Feb 20, 2023 | 04:50 AM
hakancpu™'s Avatar
Default Re: civic 2008 charging issue help
What are the 11 votlages?
do you mean each cells voltage? or should I get the pin 11 first and check others or between B pinouts have to see voltage?
while checking first start from 12 and increase as like 12-24-39...
Old Feb 20, 2023 | 04:52 AM
hakancpu™'s Avatar
now giving other issue on dash(after make jumper to obd) B2990 51 and after turnon ignition one relay on ima battery cliking 4 times then stop. while clicking that relay on dash have ima light while ignition open position then relay stop and ima clight closing on dash. with diagnostik tool getting fault P0AE1
Old Feb 20, 2023 | 07:58 AM
The 11 voltages mentioned in post #4 with the linked diagram.
Old Feb 20, 2023 | 10:23 PM
hakancpu™'s Avatar
that pin is empty
Old Feb 20, 2023 | 10:30 PM
The plug is exactly how it should be. Again, per post #4:
Viewed from BACK of plug, i.e., you probe the connector from the wire side while the connector is plugged in. It may take an uncomfortable amount of force to make contact with the metal crimps on the wires. Sharp voltmeter leads help. Auto-ranging or 20V or more scale on the meter.
The diagram in post #4 corresponds to the orientation in the TOP picture.
So, plug the thing back in to the computer and probe it per the diagram.
6-14
14-5
5-13
13-4
4-12
12-11
7-1
1-8
8-2
2-9
9-3
Old Feb 20, 2023 | 10:32 PM
hakancpu™'s Avatar
B6-B14=14,78V
B14-B5=38V
B5-B13=12V
B13-B4=0V
B4-B12=12V
B11-B12=12V
B7-B1=12V
B1-B8=36V
B8-B2=12V
B2-B9=36V
B9-B3=12V
so checked out all and looks like that
Old Feb 21, 2023 | 01:18 AM
hakancpu™'s Avatar
I think my fault could not put back the cells in correct line. So do you have any information about that cell place?
Old Feb 21, 2023 | 05:35 AM
You are checking them wrong.
Old Feb 22, 2023 | 05:23 AM
hakancpu™'s Avatar
thanks for all your help. solved that
Old Feb 22, 2023 | 08:08 AM
What are the 11 values?
