Blue LED interior trim kit
Re: Blue LED interior trim kit
Just had mine installed by the dealer today. Negotiated for $190 installed since was screwed with $550 alarm I did not want or need. Cool at night but you can spend your money better elsewhere.
Rick
Rick
I thought about it, but then I read the installation instructions at handa-accessories.com and it says you have to sacrifice the little storage cubbyhole on the left side of the dash for the on/off switch.
I just thought it would be nice if it would come on when you open the doors, so you could see the footwell when you're sitting down.
Originally Posted by JimHolmgren
Anyone self-install it? It's not too expensive, if you can do-it-yourself.
You pop off a few dashboard panels and route the wiring harness. Probably the hardest thing is the routing of the wire based on looking at the instructions. That isn't too bad. Just find the big fat main wirning harness & follow that. Then pop everything out the middle console & then the end one back around and out from under the glove box.
Overall, it looks nice at night. Not too bright. Just a soft LED glow under the dash for the driver & front passenger & in the middle pocket area. Basically, 3 small LED light just mount onto the dash board.
I bought this when I bought the mud flaps which were VERY easy to install. I do recommend that you jack up the back end a bit to make access easier to put the screws in for the back ones. Easier than removing the tires & makes things a lot quicker & less frustrating. Also, it's easiest if you break the pin attaching the deflector with a pair of pliers rather than trying to remove it.
The front ones are simplistic to install.
