Auto Stop
Old Nov 30, 2005 | 07:31 AM
ftlum's Avatar
Default Auto Stop
Hi All.
I'm trying to figure out if my auto stop is working correctly. When the engine turns back on (and to a lesser extent when it turns off), there is a split second where the engine vibrates a little. It's the sort of feeling you get when a car idles roughly. Does your car do this or not do this? I'm trying to decide whether or not to take it in for repair.
thanks,
-- Frank
Old Nov 30, 2005 | 07:45 AM
hweldon's Avatar
Default Re: Auto Stop
Mine slightly vibrates a little also. I think it's pretty normal.
Howard
Old Nov 30, 2005 | 07:49 AM
dshelman's Avatar
Yep -- normal.
Don
Old Nov 30, 2005 | 09:36 AM
livvie's Avatar
Ok... is normal for 06? I have an 03, and I don't have the vibration described.
Old Nov 30, 2005 | 09:38 AM
CGameProgrammer's Avatar
Every '06 HCH does this. It's a bit of a nuisance but it's easy to just take your foot off the brake a second or two before you actually need to start moving, so that way it's ready when you do.
Old Nov 30, 2005 | 09:42 AM
dshelman's Avatar
Mine's an '06, yes.
Old Nov 30, 2005 | 10:20 AM
gonavy's Avatar
HAH gives a quick shake too. split-second high vibes on startup are fine; if they persist once at full idle then there's an issue.
Different people have different reactions to different amount of shaking; a person saying "it vibrates a lot" is almost useless without some type of objective reference or measurement (granted that's tough to do in the driver seat without some fancy tools). It's like calling music "too loud."
Old Nov 30, 2005 | 04:58 PM
IMAhybrid's Avatar
Vegetarian
i notice that slight vibration in my 05
Old Nov 30, 2005 | 09:03 PM
zimbop's Avatar
Think about a regular car when you start it, doesn't it vibrate funny when the starter is cranking? Seems perfectly logical that it should run rough for a moment while starting up.
Old Dec 1, 2005 | 03:12 AM
dlingner's Avatar
It vibrates more when you try to accelerate right away from auto stop. If you let up the brake, wait a moment, THEN accelerate, the vibe is hardly noticeable.
