AM radio sounds terrible
Old Jul 19, 2006 | 08:12 PM
  #41
spiffnme's Avatar
Angry Re: AM radio sounds terrible
I listen to AM radio ALL the time. I just got my '06 Civic this past weekend, and I immediately was stunned at how bad the AM sounded. When I switched to FM, the sound was a bit better, but reception is horrible. Nearly all stations have static and weak signals. I've never had a worse sounding radio in a car ever. VERY disapointing.
That said, I had hoped to swap out the stereo anyway. As I'm knew the stock stereo wouldn't satisfy. Has anyone swapped out the system? It seems like it could be rather hard, with the built in navigation system. Is it possible to swap out the factory head unit at all? Or am I only going to be able to change the speakers? I'm sure a speaker upgrade will make things sound a little better, but considering how horrible the radio is, the entire thing could use replacing IMHO.
Anyone have any experience with all of this in an '06 Civic Hybrid with Nav?
Thanks!
Old Jul 20, 2006 | 05:22 AM
  #42
wmschmitz's Avatar
AllThingsAuto
Default Re: AM radio sounds terrible
Greetings;
I have read & heard that the Hybrid has an external antenna because of the battery behind the rear seat's interference w/ the in the rear window version antenna of the nonhybrid. Perhaps the interference is affecting the rear speakers and shielding is in order. My 2006 hybrid #016311, or thereabouts, doesn't seem to be too bad w/ sound quality, even in AM mode. I'll check rear/front fading and see if the rear is worse...
bmgoodman
Mar 15, 2012 05:05 AM
shawnb
Dec 4, 2006 03:01 PM
ElanC
Oct 11, 2006 05:06 AM
Eskrimast1
Aug 9, 2006 12:46 PM
