Aftermarket gauges.
Old Jun 15, 2008 | 05:25 AM
Bart's Avatar
Default Aftermarket gauges.
I've looked at the "ScanGauge" unit that's on the market, but it doesn't have everything that I would like on it. What I would like to monitor is when the engine or assist motor is working independently or in tandem and when the value assembly has changed between power or high millage configuration. So far I haven't found such a device, any suggestions?
Bart
Old Jun 15, 2008 | 05:41 AM
msantos's Avatar
Eco Accelerometrist
Default Re: Aftermarket gauges.
Bart;
The Scangauge II (with XGauge) may be the closest you'll ever get to achieving want you want. Linear Logic has been working on the Honda hybrid PID's for a while and it should not take much longer for us to have the ability to read many of the "hybrid specific values".
FEH and the Prius can already read those values and have them displayed in XGauge (scangauge).
Cheers;
MSantos
Old Jun 15, 2008 | 06:25 AM
Bart's Avatar
Originally Posted by msantos
Bart;
Can the Scangauage be firmware upgraded to read the soon to come "hybrid specific values". Or, should I wait for that newer model to appear?
Thanks for the info.
Old Jun 15, 2008 | 06:33 AM
msantos's Avatar
Eco Accelerometrist
Yes, as long as it is a Scangauge II (firmware 3.0 or better)
MSantos
Old Jun 15, 2008 | 06:38 AM
Bart's Avatar
Thanks.
I'm going to get one.
Old Jun 15, 2008 | 09:11 AM
tbaleno's Avatar
The instrumentation on the civic already has gauges you can use.
The assist bar tells you when you are using the assist motor. Since the motor only operates when the engine is on you only have two modes, engine, or engine/motor.
When you want to know if the car is in "power mode" or fuel efficiency mode, just look at your instantaneous. if it is bellow 40mpg then you are using "power" mode.
Old Jun 15, 2008 | 09:44 AM
msantos's Avatar
Eco Accelerometrist
Hi Tom;
I suspect Bart has an HCH-II based on his quote:
...What I would like to monitor is when the engine or assist motor is working independently or in tandem and when the value assembly has changed between power or high millage configuration..
As you may know, and borrowing your description, the HCH-II has an additional mode where power-flow comes from the battery pack only (EV only mode). Also, the bugger is that the OEM instrumentation is not precise enough to show sub-1 bar assists or regen which for many of us has a big say on what's truly happening.
Cheers;
MSantos
Old Jun 15, 2008 | 03:46 PM
kristian's Avatar
Agreed. I will purchase my second ScanGauge the day they announce that they have the HCH figured out. I love all of the data that I can get with it on the MMH--even more than is available with the Prius thanks to folks in this community like DesertDog.
I would really like to understand the SoC better on the HCH!
Old Jun 15, 2008 | 03:52 PM
Bart's Avatar
Hi Tom;
Cheers;
MSantos
Correct! I have an 07 HCH-II
You're also correct! The ScanGauge is going to be for my 89 Honda Civic Hatchback. But I would love to get another one for the HCH-II if and when it's able to read the car as well as it reads the Prius.
Thanks for the information folks.
Old Jun 16, 2008 | 04:20 AM
HemiSync's Avatar
Did you mean to say 1989 or 1999? SGII is for 96 cars and up.
