2012 Civic P0A27 IMA failures
Old Aug 21, 2023 | 08:43 PM
ozzum's Avatar
Angry 2012 Civic P0A27 IMA failures
2012 Honda Civic Hybrid. My car recently started throwing error codes along with the dash "Check IMA System" and "Check Brake System" messages. They all pointed to the Inverter and through this forum I learned a lot about my hybrid system. I ended up going to Bumblebee Batteries and replacing the whole MPI unit with the inverter and dc/dc. After installing it, this cleared 7 out of 8 error codes and left me with one last code of P0A27 and I am stumped. Bumblebee says it's the battery. Honda says it's still the inverter. I've checked any fuses labeled anything about the IMA. I've cleaned off terminals and connectors. I put in a brand new 12v.
What really confuses me is that if I clear the code, then start the car, the code stays off and the car runs amazing. Battery charges, engine stops when idle, I can cruise on the freeway. If I turn it off and turn it back on, the error code pops back up. If I try to drive it with the code on, the car can't get above 10 mph and drives in limp mode.
Old Dec 28, 2023 | 07:28 AM
chima lecci's Avatar
Banned
Default Re: 2012 Civic P0A27 IMA failures
How did you sort out this issue ?
nicknc
Nov 3, 2016 06:15 PM
Piquant
Nov 12, 2014 01:28 PM
Hackman
Mercury Mariner Hybrid
Sep 19, 2012 11:22 AM
travelover
Sep 14, 2008 10:21 AM
