2007 Civic Hybrid Head 240 PSI Engine Compression? What the HELL. is this normal?
WOW. i just did an Cylinder Head JOB. replace exhaust valve and head gasket.. everythings looks good.
but the Engine Compression is 240-246 Average compression
Why so high. is that normal?
and yes. i did check and adjust Valve Clearance Perfectly
Re: 2007 Civic Hybrid Head 240 PSI Engine Compression? What the HELL. is this normal
Can't Be
There is no Carbon-Up on the Cylinder Head at ALL.
IT's been from the machine SHOP..
Even the Piston Head Was SHINY before i install it.
Everything Was SHiny.
SO nope. no carbon BUilt up..
Usually, vehicles with hybrid engine has high Engine Compression, but as high as 240-246. Check your Engines' compression gauge before fixing it.
Needing to do a compression test on my hybrid and don't know what things I need to disconnect on the electrical side to keep from screwing up any computers or other electronics. Any help would be appreciated,
Curated Content Editor
02-20-2013 09:00 AM
