2007 Auto-Stop FYI
Old Jan 24, 2010 | 11:15 AM
CrimsonCivic's Avatar
Exclamation 2007 Auto-Stop FYI
I was waiting in a parking lot to pick up my wife and left the car in Drive with Auto-Stop active for about 6-10 minutes. It drained the battery all the way down, and when I went to drive the car, it used 100% gas engine only and was extremely sluggish without the aid of the electric engine for a while until the batteries charged.
FYI to those of you who might think you are saving gas by leaving the car in gear and auto-stop while you wait, it WILL drain those IMA batteries quickly and cause gas waste.
Old Jan 24, 2010 | 02:11 PM
Default Re: 2007 Auto-Stop FYI
Why would you let the car sit,doing nothing ,with the ICE running? Turn it off and conserve, I believe that is why you purchased a hybrid, is it not. Hal
Old Jan 24, 2010 | 11:15 PM
morgante's Avatar
His ICE wasn't running; the car was in auto-stop.
I find it strange that auto-stop drains the IMA battery so much after only 5-10 minutes, and have experienced this myself to some extent. If idling for a while I usually shift to neutral and turn the key to position II (accessory). Only downside to that is the radio/nav system having to reboot when you restart the car.
Old Jan 25, 2010 | 09:07 AM
Normally the ICE will restart when SOC hits the four bars? My point is, why leave a car in this state? All kinds of things could happen! Hal
Old Jan 25, 2010 | 12:08 PM
Mendel Leisk's Avatar
Was the Air Conditioning running? That'll do it.
Old Jan 25, 2010 | 09:38 PM
Yeah, A/C was turned on. Maybe in Auto mode though. I don't remember.
Old Jan 27, 2010 | 12:22 PM
So AC use (it runs off the IMA battery during Auto Stop) drained the battery, but:
This is not supposed to happen. If the IMA battery's state-of-charge drops low during AutoStop, the car should start back up, in order to prevent over-depletion of charge. I'd:
1. Shut down whenever you stop the car for protracted time, and/or shut of AC.
2. Run it by the dealership. Be careful though, it might be an out-of-warranty issue.
Old Feb 26, 2010 | 08:05 PM
giantquesadilla's Avatar
This happened to me as well, about 3 months ago. I was sitting for 10 minutes or so in auto-stop. AC was off. After about 10 minutes, battery dropped from 5 bars directly to 0 and went into forced regen. It was odd...
Old Feb 28, 2010 | 09:01 AM
My hunch: it's not drain, just recalibration.
AJR
Feb 13, 2008 06:45 AM
Myrddin157
May 24, 2007 06:08 PM
nokoon
Feb 13, 2006 03:58 PM
grayhawk
Sep 11, 2005 05:55 PM
MoJoWryter
Jun 23, 2005 12:52 PM
