17" Si wheels on HCH2?
Old Aug 15, 2006 | 10:08 AM
JayTea's Avatar
Default 17" Si wheels on HCH2?
Has anyone tried putting on a set of 17" Civic Si wheels on a HCH2? I read somewhere that these wheels didn't fit due to regenerative brakes getting in the way of the wheels rotation.
Old Aug 15, 2006 | 10:44 AM
exbauer's Avatar
Default Re: 17" Si wheels on HCH2?
you will need spacers...which i don't reccomend. but, since it is so little it shouldn't be that big of a deal. 3mm is what you need. it is the same on the other civics besides the Si.
Old Aug 15, 2006 | 11:19 AM
Double-Trinity's Avatar
Well, I think that source may have been poorly written as to give
that impression. The regenerative braking is caused by the elecrtic motor -- which is integrated with the flywheel on the engine. Instead of providing boost, that motor acts as a generator charges the battery, so the regenerative braking is essentially a form of engine braking -- there are no additional brake rotors associated with it by the wheels. Fitting a custom wheel should be no different on the Hybrid than the Non-Hybrid Civic.
Old Aug 15, 2006 | 02:11 PM
exbauer's Avatar
Well actually the brake thing...the thing that holds the pad on the Civic Si and regular Civics including the hyrid are different. You need at least 3mm spacers to clear them.
MMH06
Feb 19, 2010 07:08 AM
MMH06
Oct 27, 2009 07:11 AM
2007HCHOttawa
Sep 18, 2007 08:41 AM
kb101
Jan 24, 2006 05:16 AM
lkewin
Oct 31, 2005 05:20 AM
