When to replace timing belt?
Old Feb 13, 2010 | 09:19 PM
spent2much's Avatar
Default When to replace timing belt in 2006 Honda Accord Hybrid?
I have a 2006 HAH, which now has 92,000 miles on it.
I am wondering what is the recommended mileage interval for
changing the timing belt?
Old Feb 14, 2010 | 11:42 PM
bar10dah's Avatar
Default Re: When to replace timing belt?
I seem to remember something like 84 months or 105,000 miles. But, I don't have my owner's manual handy to verify that. Have you looked into your own owner's manual yet?
Old Feb 16, 2010 | 09:00 PM
spent2much's Avatar
Yes, that's right....I checked with the dealer today, and they said
105,000 mi. Will replace, at that time, the timing belt, tensioners, water pump, cam and crank seals, which comes in a "kit" on some websites.
(Since you have the car apart, its just handier at that time to change the water pump and seals at that time.
Old Feb 18, 2010 | 12:17 AM
qiaodigg's Avatar
Passing
Old Feb 19, 2010 | 06:42 PM
Mendel Leisk's Avatar
Timing belt replacement is not something I envy the dealership for, better them than me. With the tranverse mounted engine it's a bear getting at things down the side, in close quarters. And there's lots of tricky alignment, heavy torque values, and so on. I believe one of the engine mounts has to be partially removed, as a belt is captured by it. At least that is the case on some models. And they are right: it is an opportune time to replace other things in there. It might be a good time to replace the exterior accessory belts while they're at it: alternator, power steering, AC, and what have you.
cbxtc6
Sep 15, 2014 12:54 PM
Ed_of_Indy
Nov 7, 2011 01:19 PM
houstoib
Aug 31, 2011 12:44 PM
renod
May 6, 2011 01:33 PM
UWAdventurer
Jun 24, 2010 07:48 AM
