Info. on Auto A/C setting?
Old Oct 11, 2005 | 11:47 PM
weyus's Avatar
Default Info. on Auto A/C setting?
I just recently started trusting the "AUTO" setting on my A/C to decide how to run the A/C.
Does anyone have any insight into how it works? I have noticed that when it is much much (> 10 degrees) warmer outside than inside, that the A/C cranks up a bit. Definitely have noticed different fan speeds at different times.
Just curious if any of y'all understand what makes it tick.
Thanks,
Wes
Old Oct 12, 2005 | 12:20 PM
gonavy's Avatar
Default Re: Info. on Auto A/C setting?
All I know is that it will do whatever is necessary to achieve and then maintain a set temp. If it thinks another notch of fan speed will do the trick, it does it. It will go into recirc by itself when ambient is over 85, I think?
I never use auto- would rather run AC in recirc on low fan speed all the time, the few times I do use it. I prefer having all 4 windows cracked an inch or so when on the hwy.
Old Nov 26, 2005 | 12:27 PM
bar10dah's Avatar
Does this car ONLY have the electric A/C? Meaning, do we have a standard A/C compressor that runs when the ICE is on?
Old Nov 26, 2005 | 07:03 PM
gonavy's Avatar
Well, here's a good-sized hint:
The compressor is sitting on the passenger side, very front, and is the only thing in the engine compartment that has both a belt and big orange conduit running to it.
(It's run by both the engine and 144VDC- a hybrid AC on your hybrid car! clever, eh?)
Old Nov 26, 2005 | 10:17 PM
bar10dah's Avatar
Yeah, I guess I should have looked under the hood before asking that question.
I was wondering because, my MPG doesn't seem to matter if I run the A/C or not. At least, it hasn't affected my usual commute MPG.
I do, feel the change in air when the car autostops. I wouldn't say the temp changes, but the feel of the air does. I don't know how to explain it.
Old Dec 21, 2005 | 07:07 AM
brendanjerwin's Avatar
The fan speed reduces and the AC compressor switches to electric mode. That would explain the difference in "feel" of the A/C.
As a side note, if you have the fan speed turned all the way up manually that can disable Auto Stop...
Old Dec 21, 2005 | 08:03 AM
savvyshopper111's Avatar
I have recently been parking my car at the curb overnight and have noticed something I thought was kind of strange with the A/C. In some colder mornings (well cold for California), the temp is around 55 degrees or so. And on those mornings, I don't even have the heat on and I will feel hot air coming from the vents. Is this hot air based on the last temp setting, say 75 degrees or whatever temp I left it at last time? And on the contrary, on some warm days I go to turn on the A/C to cool down the car and I will still get warm air. These 2 "problems" generally occur first thing in the morning though. Any thoughts?
Scubapeg
Oct 28, 2006 03:15 AM
yellowdn
Jun 21, 2006 10:06 AM
Momboy007
Apr 4, 2006 07:00 PM
Mr Bosox
Feb 10, 2006 10:33 AM
