HAH Hybrid Battery Warranty
Old Dec 14, 2008 | 09:40 AM
scizolt's Avatar
Default HAH Hybrid Battery Warranty
Does anyone have a credibal link that states the true Hybrid Battery warranty? I'm kind of confused. I'm seeing 3/36000 and also seeing 8/80000. I just want to be absolutely sure on this. I'm looking into purchasing and 05 HAH and just curious about this. Thanks for your time!
Old Dec 14, 2008 | 12:41 PM
georgej's Avatar
Default Re: HAH Hybrid Battery Warranty
Scott
The warranty is for 8 years/80k miles for most of the IMA components. This includes the battery assembly located behind the rear seat.What's covered is listed in the warranty booklet that came with the HAH. You should be able to get a copy from your Honda dealer if it's missing. Also if you live in Califonia the warranty covers some components for a longer time..
George
Old Jan 6, 2009 | 11:28 AM
Fast_Hybrid's Avatar
Hybrid battery is 8/80. Regular battery in engine compartment is different. That may be what you see.
Also, I just had the IMA software in my 2005 updated after the "check IMA" light came on a couple of weeks ago. It was a free fix at the dealership under warranty.
Old Jan 8, 2009 | 11:41 PM
thebutler7's Avatar
This
System Covered/Part Name Federal
CA
CA/CT/MA/
ME/VT
Crankcase Control System
Positive Crankcase Ventilation (PCV) Valve 3/36 3/50
Engine Oil Fill Cap 3/36 3/50
Evaporative and Refueling Emissions
Control System
Fuel Tank (including Fuel Tank Vapor/ 3/36
7/70
Liquid Separation Valve and Vapor
Recirculation Tube)
Fuel Tank Pressure Sensor 3/36 3/50
Fuel Pump Module 3/36
7/70
Fuel Fi
lter (including Fuel Pressure
Regulator)
*1 3/36 3/50
Fuel Fill Pipe 3/36 3/50
Fuel Fill Cap 3/36 3/50
Evaporative Emission Lines and/or Hoses 3/36 3/50
Evaporative Emission Canister 3/36 3/50
Evaporative Emission Valves 3/36 3/50
Exhaust Gas Recirculation (EGR) System
Exhaust Gas Recirculation (EGR) Valve
(including EGR Valve Position Sensor) 3/36 3/50
Exhaust System
Catalytic Converters
8/80 8/80
CA
CA/CT/MA/
ME/VT
Exhaust System (cont’d)
Exhaust Pipe (engine to catalytic
converter or between converters) 3/36 3/50
Ignition System
Ignition Coils 3/36 3/50
Spark Plugs 3/36 3/50
Crankshaft Position Sensor 3/36
7/70
Camshaft Position Sensor 3/36 3/50
Fuel Injection System
Engine/Powertrain Control Module
8/80 8/80
(including Barometric Pressure
Sensor and Software Upgrades)
Throttle Actuator Control Module
8/80 8/80
Accelerator Pedal Position Sensor 3/36 3/50
Injectors 3/36 3/50
Fuel Rail 3/36 3/50
Fuel Lines and/or Hoses 3/36 3/50
Knock Sensors 3/36 3/50
Oxygen Sensors 3/36 3/50
Air Fuel Ratio Sensor 3/36 3/50
MAP Sensor 3/36 3/50
Engine Coolant Temperature Sensor 3/36 3/50
Federal and California Emissions Warranties Parts List
APL 28253 (0409)
This list details the components covered and the warranty duration in years and miles, whichever comes first. Your vehicle may
not be equipped with all of the parts listed.
Federal
column applies to all vehicles registered and normally operated in all states other than California/Connecticut/
Massachusetts/Maine/Vermont.
California
column applies to all vehicles registered and normally operated in California/Connecticut/Massachusetts/
Maine/Vermont.
2005 Accord Hybrid
CA
CA/CT/MA/
ME/VT
Fuel Injection System (cont’d)
Intake Air Temperature Sensor 3/36 3/50
Thermostat 3/36 3/50
OBD System
Malfunction Indicator Lamp (MIL) 3/36
7/70
Data Link Connector (DLC) 3/36
7/70
Transmission Control System
Input Shaft (Mainshaft) Speed Sensor 3/36 3/50
Output Shaft (Countershaft) Speed Sensor 3/36 3/50
Shift Solenoid & Clutch Pressure Control 3/36 3/50
Solenoid Valves
Transmission Fluid Pressure Switch 3/36 3/50
Shift Control Solenoid Valves 3/36 3/50
Transmission Range Switch 3/36 3/50
In
take Air System
Throttle Body (including Throttle Position 3/36 3/50
Sensor and Throttle Actuactor)
Mass Airflow Sensor 3/36 3/50
Intake Manifold Assembly 3/36
7/70
Intake Manifold Tuning Actuator Assembly 3/36 3/50
Intake Air Resonator 3/36 3/50
Intake Air Ducts 3/36 3/50
Air Cleaner Housing 3/36 3/50
Air Cleaner Housing Cover 3/36 3/50
Air Cleaner Element
*2 3/36 3/50
Variable Cylinder Management System
Spool Valve Assembly 3/36 3/50
Engine Oil Pressure Sensor 3/36 3/50
CA
CA/CT/MA/
ME/VT
Integrated Motor Assist System (IMA)
Battery Assembly (including all internal
8/80 8/80
components)
DC-DC Converter
8/80 8/80
Motor Control Module
8/80 8/80
Motor Power Inverter Module (including
8/80 8/80
software updates)
8/80 8/80
Motor Rotor
8/80 8/80
Motor Stator
8/80 8/80
Busbar 3/36 3/50
Bypass Contactor 3/36 3/50
Bypass Resistor 3/36 3/50
High Voltage Contactor 3/36 3/50
Battery Current Sensor 3/36 3/50
Motor Rotor Position Sensor 3/36 3/50
Motor Current Sensor 3/36 3/50
Motor Power Cable 3/36
7/70
High Voltage Motor Power Inverter 3/36 3/50
Module Cable
Intelligent Power Unit Air Duct and Fan 3/36 3/50
Power Control Unit Air Duct 3/36 3/50
Motor Power Inverter Module Fan 3/36 3/50
Control Relay
Miscellaneous Parts
that are used in conjunction with the items in
this list are covered. Some examples are: clamps, brackets, piping,
nuts, bolts, fasteners, switches, sensors, solenoids, wires, harnesses,
connectors, seals, and gaskets.
1 Fuel filter replacement and fuel tank flushing are covered when
contamination results from a defect in material or workmanship.
2 Covered up to the first required replacement only; see the
maintenance schedule in the Owner’s Manual.
2005 Accord Hybrid
is from the honda website.
Old Jan 8, 2009 | 11:42 PM
thebutler7's Avatar
System Covered/Part Name Federal CA
CA/CT/MA/
ME/VT
Control System
Fuel Tank (including Fuel Tank Vapor/ 3/36 7/70
Recirculation Tube)
Fuel Pump Module 3/36 7/70
Fuel Filter (including Fuel Pressure
Regulator)*1 3/36 3/50
Exhaust System
Catalytic Converters 8/80 8/80
CA/CT/MA/
ME/VT
Ignition System
Crankshaft Position Sensor 3/36 7/70
Engine/Powertrain Control Module 8/80 8/80
Throttle Actuator Control Module 8/80 8/80
Injectors 3/36 3/50
Fuel Rail 3/36 3/50
APL 28253 (0409)
Federal column applies to all vehicles registered and normally operated in all states other than California/Connecticut/
California column applies to all vehicles registered and normally operated in California/Connecticut/Massachusetts/
Maine/Vermont.
2005 Accord Hybrid
CA/CT/MA/
ME/VT
OBD System
Malfunction Indicator Lamp (MIL) 3/36 7/70
Data Link Connector (DLC) 3/36 7/70
Solenoid Valves
Intake Air System
Intake Manifold Assembly 3/36 7/70
Air Cleaner Element*2 3/36 3/50
CA/CT/MA/
ME/VT
Battery Assembly (including all internal 8/80 8/80
components)
DC-DC Converter 8/80 8/80
Motor Control Module 8/80 8/80
Motor Power Inverter Module (including 8/80 8/80
software updates) 8/80 8/80
Motor Rotor 8/80 8/80
Motor Stator 8/80 8/80
Busbar 3/36 3/50
Motor Power Cable 3/36 7/70
Module Cable
Control Relay
Miscellaneous Parts that are used in conjunction with the items in
*1 Fuel filter replacement and fuel tank flushing are covered when
*2 Covered up to the first required replacement only; see the
2005 Accord Hybrid
hunter44102
Aug 18, 2015 12:24 PM
EdRotberg
Honda Insight
44
Aug 24, 2014 12:58 AM
AlanWBaker
Dec 15, 2011 09:33 PM
Resist
Nov 1, 2006 02:49 PM
