6 Disc CD Changer
I have the 6-disc CD Changer with the XM Radio and have a question. I do not have the NAVI option.
The manual states that to change from one disc to another disc you can simply push one of preset buttons (1-6). This works for me. The manual also states that you can also press Preset 5 (Disc -) or Preset 6 (Disc +) to select the next disc in sequence. This option does not work for me. When I press either of these presets, I go to CD #5 (if Preset 5 is pressed) or CD #6 (if Preset 6 is pressed) and cannot cycle up or down through the 6 discs in the changer as the manual states.
Does anybody else have this same issue? I am referring to the owner's manual (Page 121 (3rd column)). Also, are those other functions above the presets ever used (i.e. Rew, FF, Play/Prog, NR) or are those for a tape player option??
Thanks in advance for the help!
Just got a call from Honda.
There is a misprint in the manual. Presets 5 and 6 (Disc - and Disc +) are used to cycle up and down through CDs if you have a CD changer add-on, like the ones commonly installed in a trunk. The manual does not specify this specific requirement.
phenderson
Nov 30, 2009 01:05 PM
