Dash warning lights on and car is sluggish after jump start.
Old May 10, 2022 | 11:03 PM
  #41
2014 HCH3's Avatar
Default Re: Dash warning lights on and car is sluggish after jump start.
IMA light is back on. Pulled some blink codes tonight: 32, 57, 85. While reading the codes, I noticed a code on the upper dash, which I haven't seen before:
Old May 11, 2022 | 05:42 AM
  #42
Oh well... wishful thinking.
I don't have the blink codes for your year. For the 06-11 models IMA blinks:
P0A78 (32) MCM Internal Circuit Malfunction
P1440 (57) MCM Circuit Malfunction
P15A5 (85) Motor Current Sensor Circuit Malfunction
B2999 A problem in the A/C compressor delivery valve.
Did you have any CEL blinks?
Old May 11, 2022 | 12:30 PM
  #43
2014 HCH3's Avatar
Stealership says it's the power inverter, which has a factory warranty of 15 years, and will arrive tmw at the earliest. Fingers crossed that they get it right.
Old May 11, 2022 | 12:42 PM
  #44
The ONE time I like the dealership... when they have to do warranty work.
Good luck!
Old May 11, 2022 | 12:53 PM
  #45
2014 HCH3's Avatar
Good luck!
So true! Thanks again. I'll report back.
Old May 11, 2022 | 09:32 PM
  #46
2014 HCH3's Avatar
Now that I have a fancy new microprocessor battery charger/tender, would it be beneficial to periodically trickle charge the 12 volt battery, and if so, how often?
Old May 11, 2022 | 10:32 PM
  #47
Anything helps. Car charging systems are pretty marginal.
If you know you're going to have the car sitting for more than a few days, put it on a float charge.
Every 2-4 weeks, let it sit on the charger overnight for ~12 hours.
Old May 15, 2022 | 11:21 PM
  #48
2014 HCH3's Avatar
I got my car back Saturday. It seems to be back to normal. The stealership doesn't want to reimburse me the $180 I had to pay them for the two codes they pulled initially, but per the warranty booklet, emissions system-related parts, labor and diagnosis are covered by a 15/150 warranty, and the IMA is part of that system. I'm going to escalate it.
As I was looking through the warranty booklet, I learned that a replacement battery purchased from Honda is covered by a 100 month warranty. That's >8 years! I did not know that.
Old May 16, 2022 | 05:42 AM
  #49
Glad the car is sorted. Good luck with Honda.
Old May 17, 2022 | 10:20 PM
  #50
2014 HCH3's Avatar
Smile Re: Dash warning lights on and car is sluggish after jump start.
I contacted the gen'l mgr with the warranty manual in hand, and he agreed to refund the diagnosis fee. Sometimes it pays to be squeaky!
