Wanting to squeeze more life out of a dying battery
Old Oct 19, 2017 | 10:09 PM
Woops's Avatar
Default Re: Wanting to squeeze more life out of a dying battery
Pull the IPU lid and check the 11 block voltages after sitting 10+ hours. If they have a small deviation (<0.2V), grid charging is likely a solution.
Hey Keith, thanks for the quick response. It's sitting now so I can test it tomorrow.
If there's a small deviation, I will be building my own charger / discharger as I have an old PC PSU and some of the other parts laying around.
I will need to purchase the harness from Hybrid Automotive so that it can power the built-in fan so I don't have to take the pack out of the car.
Any chance you know what type of connector the harness is terminated in, so I can interface with it?
Thanks.
Old Oct 19, 2017 | 10:23 PM
Something like this, but I can't say for certain. Not sure of the pinouts either.
https://www.alliedelec.com/te-connec...BoC1ZIQAvD_BwE
Old Oct 21, 2017 | 03:36 PM
Woops's Avatar
Am I supposed to do this BEFORE or AFTER the "3x 12v reset" discussed here:
https://www.greenhybrid.com/forums/f...21/#post263170
thanks.
Old Oct 21, 2017 | 03:38 PM
The 3X 12V reset can mask issues. If you do the 3X 12V reset, I would wait until the car codes again or shows frequent recalibrations before checking the taps.
Old Oct 21, 2017 | 03:42 PM
Woops's Avatar
Thank you, I really appreciate all your help.
New owner of an 06 HCH-II here, hence the username.The car and battery only have 50k miles so I'm optimistic for good results.
Old Oct 21, 2017 | 03:46 PM
LOL on name...
Not trying to be a d1ck, but optimism with the HCH2 battery almost always meets with disappointment. Maybe you'll get lucky, but keep your expectations low. The fact that you're having problems already is testament to the fact that low mileage hybrids tend to have battery problems, and HCH2 batteries are just turds.
The BEST possible outcome is that you get a functional battery that needs somewhat regular maintenance, e.g., grid charge overnight every 90 days and do a full recondition once/year.
Old Oct 30, 2017 | 04:51 PM
Woops's Avatar
LOL on name...
fair enough
where are the 11 block voltages located and how do i test them -- where do i put the red lead and the black lead from my multimeter? do i open the battery cover circled in red and go to the sticks directly, or can i test it at one of the other places here? colored circles for reference:
https://i.imgur.com/kDV17Uh.jpg
Old Oct 30, 2017 | 05:08 PM
Yellow circled plug in place (do not disconnect. Just probe the back of the plugs):
https://www.dropbox.com/s/l4sj188ldw...Check.png?dl=0
pins 1 & 7 are at the top.
user 93084320834
Sep 6, 2013 10:01 AM
tecz0r
Aug 29, 2013 09:20 PM
08MMHybridHappy
Jul 20, 2010 07:48 PM
shoebox303
Aug 10, 2006 06:53 PM
