Turning Air Conditioning off by default?
Old Jul 10, 2010 | 01:14 PM
Default Re: Turning Air Conditioning off by default?
Hi Mendel:
There is a button to turn the A/C off Mendel. Just push the A/C button and it turns the air on or off. I just discovered this a mth. ago. Try it. H
Old Jul 16, 2010 | 01:03 PM
Mendel Leisk's Avatar
Oh, I know about the AC on/off button. But on past Honda's this was the button that determined if you got AC or not, a separate AC switch. If you turned it off it stayed off. Now with the HCHII, every time you turn the system off, and then on again, you've got AC.
Old Jul 17, 2010 | 07:36 AM
Hi Mendel: On my 06 when I turn it off it stays off until you actually make the change. I had to tell my wife to turn it on at least once a month just to re lube the compressor. I wonder why yours would be different than mine? H
Old Jul 17, 2010 | 10:15 AM
What happens if you hit the off button, and then Auto? Or alternately hit off and then turn the fan speed dial up one click?
With ours both of those actions will leave you with AC on, regardless of how it was set prior to turning the system off. The first action causes everything to be set to defaults, the second action puts everthing to your previous settings, accept for AC on. In short, the dang AC keeps going on every time you switch the system back on, by whatever method.
Old Jul 17, 2010 | 02:06 PM
Hi Mendel:
I use Auto setting only. If for some reason I prefer not to have air on, I push the A/C button and it turns the air off. It also notes the air is turned off. The air will not come on again until you push the A/C button again. My car is in Victoria so I cannot go out and see what other things do, sorry! H
Old Jul 17, 2010 | 03:01 PM
cylverbak's Avatar
Harold, thanks for mentioning lubing the compressor. That's probably why, when I saw that key combo to force the A/C off, I didn't do it.
Hi Mendel, I'll have to check the way my controls behave. Can't say I've ever paid that much attention, sometimes the air is on, sometimes off but I can't remember how I would have left it.
Old Jul 17, 2010 | 07:49 PM
I find with Auto setting the AC is almost invariably on. One way to tell: you can hear the compressor running during Auto-Stop. It's not a deal braker, but in the old days there was an AC switch: click it off and AC didn't happen, period.
Old Jul 18, 2010 | 09:48 AM
I can not hear that well, but when it shows A/C off it feels like it is off. Have you tried it in Auto mode and then push A/C button once to turn A/C off. I don't think the A/C runs? H
Old Jul 18, 2010 | 09:59 AM
Harold, yes: if I push Auto, and then AC off, it is off, that's a given.
The OP's (and mine) concern: it would be nice to shut AC off, and it stay's off, even if you hit Auto. In short a single, dedicated AC switch: shut it off it stays off, just as if you'd snip the wires running to the compressor, LOL.
Old Jul 18, 2010 | 10:32 AM
Gairwyn's Avatar
Think green.
These climate control systems are so dang confusing.*
I once had a Plymouth Duster with the most basic climate control ever. Either I got to roll down the windows, or open the air vents. These consisted of 2 boxes under the dash that had doors that you unlatched and opened. They were big enough that you could stash a small book inside them. Primitive, yet effective.
*Sorry I just had to vent. haha.
