Trans Fluid Change
Old Sep 25, 2007 | 03:44 PM
medicmike's Avatar
Default Trans Fluid Change
My B123 indication is on, telling me to change the transmission fluid. I've not done this before so I have a few questions. First, where exactly IS the trans drain plug? Next, how much total trans fluid does it take if you drain/fill 3x as the manual says. I know not all the fluid drains when the plug is removed, so how much do I need for 4 fills? Lastly, where is a good place to get the long-neck funnel needed to do the job?
Thanks!
Old Sep 25, 2007 | 07:21 PM
Default Re: Trans Fluid Change
There is a thread on HCH2 page covering all you need to know including picture. H
Old Sep 25, 2007 | 08:02 PM
medicmike's Avatar
I went looking for the specific thread but didn't find one with detailed instructions or pics. Can the CVTs be "power flushed" at the dealer or must they use the same inefficient method I have to?
Old Sep 26, 2007 | 05:04 AM
williaea's Avatar
My understanding is that the dealer would use the same method as you. Somewhere (I forget where - sorry) I saw a Honda service bulletin that recommends against power flushing the transmission of any Honda. It was either somewhere on Greenhybrid or on HondaSUV (my wife has an '07 CR-V).
Eric
Old Sep 26, 2007 | 08:14 AM
I think, your method. H
Old Sep 26, 2007 | 12:21 PM
medicmike's Avatar
Thanks for the help, I did finally find the thread will all the pics. It was an HCH I, though. I'm assuming the trans is to the right of the oil pan if you are looking at the front of the car?
Old Sep 26, 2007 | 02:47 PM
Yes to the right.
Old Sep 27, 2007 | 02:33 PM
Default Trans Fluid Change flushing
I had a nice conversation with a Honda engineer on the topic of CVT oil changes, and his advice was that the 30K oil changes are just that, drain and refill with fresh trans fluid. The only time that the drain, fill, drain, fill, drain, fill comes into play is if there is a problem with the CVT. Otherwise it is just drain and fill.
Old Sep 27, 2007 | 06:18 PM
Good to here about that. I hate wasting oil for a flush only. Thanks, H
yu888
Jun 25, 2012 05:15 PM
kalamazoo
Jan 22, 2010 03:53 PM
UWAdventurer
Nov 30, 2008 04:28 PM
bear15
Jun 19, 2007 05:43 PM
atikovi
Dec 22, 2006 11:40 AM
