summertime tire pressure
Old Jun 6, 2007 | 12:18 PM
msantos's Avatar
Eco Accelerometrist
Default Re: summertime tire pressure
Originally Posted by JavaJ
MSantos, do you have the Insignia SE200 tires on your car? I figure I can pretty much copy what you are doing since Calgary and Winnipeg would have the same temps (currently running 40 all around and was wondering if going higher would be beneficial). Also, have you noticed a loss of traction going so high on the highway (and do you travel over 110KMPH often at those PSI's).
Hi Jason;
I have the OEM Dunlops on both my HCH-II cars.
On my 06 HCH, I have my tire pressures set at 48 PSI in the front and 46 in the rear tires. I also have a direct TPMS installed to monitor the temps for each tire just to be sure.
On my wife's 07 HCH, I have the tires set at 42F and 40R.
Inflating the tires for better FE is a perenial technique that shows very measurable results for most folks. I know some folks who are running their Dunlop tires (max rating at 44psi) in the 50's and can claim much improved FE over me.
I don't do much highway travelling, but when I do, the obverved tire temps are pretty low for each tire never above 40C (even with the sun hitting on them). I would surmize that the higher inflation promotes less friction and hence less heat generation. I never go above the speed limit which is mostly 100km/h.
Cheers;
MSantos
Old Jun 6, 2007 | 12:54 PM
DougD's Avatar
Happy Camper Enthusiast
Originally Posted by TheBundo
"terrible" FE won't be caused by tires at 32 psi, it's a minor factor in that range (from 32 psi up to the limit). The hot are is not "dense", hence the lower mpg
Um, that's backwards. Because hot air isn't as dense, it requires less fuel charge to ignite it, so the engine runs leaner in warmer air and FE *improves* with temperature, as virtually all of us observe with these cars. (I don't think I've ever had a car where it improved *so much* -- in my car it looks like about a mpg for every 10 degrees of temp.)
But, in the department of never-something-for-nothing: power *per unit* of fuel/air is stable, so when there's denser air and more fuel charge, the engine makes more power, which is why racers like running in cool air. And you know how much *they* care about FE. Because most of us don't drive our cars around at max power all the time, we tend not to notice or miss the slight decrease.
cheers --
doug
Old Aug 19, 2007 | 05:22 PM
xcaliber's Avatar
So which is it? Do we follow the recommendation on the side of the different brands of tires, or the recomendation by Honda?
I also have a chevy malibu, and the Dealership says tire pressure should be no more than GET THIS.... 28 PSI. That is not a typo. twenty -eight.
I keep my tires inflated to 35 PSI year round, And like in a previous post... I caught them "deflating" my brand new tires down to 28 from 35!
under inflated tires cause excessive wear. I suppose this is so they can sell me another new set of tires allot sooner.
xcaliber
Green Bay, WI
Old Aug 20, 2007 | 07:02 AM
livvie's Avatar
there are no recommendation on the side of the tires.... they only list out ranges and max psi.
you should always follow OEM and never exceed MAX psi on side of tire.
I run anywhere from +5 to +10psi. I have also run at MAX psi just to see what would happen. MPG did not go up, nor did it drop, it pretty much stayed the same to OEM psi readings. But, handling in the dry and especially in the wet was improved. I did not hydroplane as much at MAX psi.
Curated Content Editor
Aug 4, 2014 03:00 PM
bwilson4web
Aug 23, 2008 03:51 PM
Oiler
Jul 19, 2007 06:50 AM
RoyalF
Apr 10, 2005 05:40 PM
milkandcheese
32
Jul 19, 2004 08:05 PM
