Sucessfully Reconditioning an IMA Battery Pack
Old Apr 17, 2026 | 04:28 PM
  #101
Abeachtree's Avatar
Thumbs up Re: Sucessfully Reconditioning an IMA Battery Pack
Rather than cycling, I recommend the following:
Charge to dV termination with cooling. Sticks should be comfortably warm to the touch.
Wait 5 minutes with cooling
Discharge each stick to 6V at the maximum current the B6 will permit - 0.7-.8A typically. Record mAh
Discharge to 2.4V @ 0.4A. Record mAh.
Charge at 0.4A until over 6V, then charge at max to dV. Set aside.
Hey cheers for the super swift reply and feedback. Yes, i didn’t know that imax B6 had to be specifically skyrc brand so I have clones…
I’m interested in your point about "Discharge to 2.4V @ 0.4A" which seems to go much lower than the 0.9 to 1.0V per cell discharge standard for NiMH. Is this what is known as "deep discharging"…? Any risks to be aware of?
Old Apr 17, 2026 | 07:25 PM
  #102
Default Re: Sucessfully Reconditioning an IMA Battery Pack
Yes. Not as described.
helmy
Sep 11, 2020 07:05 AM
Alex Austin
Mar 6, 2018 12:50 PM
dosmastr
Dec 9, 2017 04:24 PM
dosmastr
Aug 5, 2017 09:08 PM
John Zheng
Dec 21, 2016 12:17 AM
