Rear Suspension
Old Jun 8, 2008 | 06:07 AM
kourtak's Avatar
Default Rear Suspension
I have a 2007 Civic Hybrid, and I've noticed that the when there is some weight in the car, the rear wheels aren't parallel to each other any more. The rear wheels angle out a little. Is this normal for the Civic suspension? I've noticed this also on some older, small BMW's -
Thanks for any input!
Old Jun 8, 2008 | 09:09 AM
spinner's Avatar
Default Re: Rear Suspension
Even without a load, you should see a slight lean-in of the rear wheels on the HCH-II. It is negative camber and it's designed that way. You mentioned the BMW, and I have noticed it mostly on Mercedes-Benz vehicles, including the child brand smart. It is one of several ways to provide rear stability and traction.
Old Jun 8, 2008 | 10:08 AM
Bobs Metallic Pearl's Avatar
Or you could have this issue:
https://www.greenhybrid.com/discuss/...eplaced-17377/
Before having the work completed, I noticed a slant to my rear wheels, afterwards, not so much....for sure is worth the effort of checking out.
Old Jun 14, 2008 | 06:29 PM
kourtak's Avatar
Thank you! I went to the dealership, and sure enough, the control arms need to be replaced. They would not have told me about it if I hadn't brought in all of the documentation.
Old Jun 16, 2008 | 08:23 AM
BenderX's Avatar
Sounds like you have/had a legit problem.
I had a BMW 5-Series that always looked like the rear wheels were not quite right, but whenever I'd verify it, they were perfectly vertical. The tire wear was uniform too, so it was just an optical illusion.
nathanso
May 18, 2008 12:12 PM
pianewman
May 10, 2007 01:03 PM
WRXSTi
May 4, 2007 06:05 PM
dantheman
Oct 28, 2006 05:24 PM
exbauer
Jun 17, 2006 05:22 PM
