Reality Check
Old Jan 25, 2010 | 05:48 PM
linx3566's Avatar
Default Re: Reality Check
Honda batteries can also replace individual cells - Hybrid Battery Repair can do this job for about 1250 as per their website
Old Jan 30, 2010 | 01:37 AM
cwerdna's Avatar
Originally Posted by Tommy T
Interesting about the nature of interconnected individual cells. We went to drive a Prius a while back and the salesperson stated that Toyota's battery design enables replacement of individual cells.
Could this be a difference between Honda and Toyota's design? I did scan some Prius boards and saw almost no mention of recal and battery replacements as we are seeing with our HCH-IIs.
From what I've gathered on Priuschat, individual cell replacement is tricky as you need to replace bad cells w/others in nearly the same condition, otherwise you'll have an unbalanced pack causing other problems.
I don't think Priuses have anything similar to a "recal" because of how HSD works. Probably best to get someone who has both an IMA and HSD hybrid who has more technical knowledge than me to comment on that. Supposedly a symptom of failing battery when there are no warning lights and codes is that the SOC goes from full to empty or the opposite very quickly. IIRC, the battery fan ends up running a lot more than normal too.
As for replacements, no, there haven't been a ton, but it seems I see an increasing (not surprisingly) # of 1st gen Prius owners w/failed/worn out batteries. There aren't many 2nd gen (04 to 09) w/failed/worn out batteries.
kengrubb
Feb 28, 2009 07:23 AM
philmcneal
Jan 11, 2006 02:57 PM
lkewin
Oct 20, 2005 12:33 AM
jasoncobb
Sep 27, 2005 08:36 AM
