Rattle and Roll
Old Nov 6, 2008 | 01:08 PM
GreenTea's Avatar
Default Re: Rattle and Roll
Thank you! I never even thought of that. I will try some grease to alleviate the problem.
Old Nov 7, 2008 | 03:59 PM
bill717's Avatar
You may remember me posting earlier in this thread about a squeaking noise from the rear of my HCHII. Well after 2.5 hours at the dealership....it turned out to just be two body panels in the rear that were rubbing. It was fixed under warranty but it sure took them long enough .
Old Nov 7, 2008 | 05:04 PM
bill717's Avatar
Good to year you were able to fix those rattles yourself. I guess you're right. If I had tried to fix it myself it would have taken me more than 2.5 hours and I likely wouldn't have fixed the problem.
Its good that we have this little "rattle database" going so that people can refer here and fix rattles themselves
Old Nov 7, 2008 | 05:58 PM
rwslemko's Avatar
I sometimes have a little rattle that seems to come from under the steering wheel. Sometimes pushing up on the steering wheel makes it go away, but I haven`t found the source.
Old Nov 17, 2008 | 01:14 PM
steve04's Avatar
In mine, a 2006, the front door panels rattled. The large expanse of plastic above the arm rests rattled against the interior of the door, and because it is so large and flat the sound sort of bounced straight into my ears.
When I replaced the front speakers, I used a few self-adhesive weather stripping bits between the door structure and the interior panel, which took care of the sound. I've also noticed a few places where the door interior can rub the side of the dash, or against the structural pillar between doors. A product like Armorall might either solve the problem or make it worse...not sure!
About the speakers: the factory speakers are the cheapest, lightest pieces of cardboard junk imaginable. Even a pair of $60 speakers combined with the factory stereo will make a remarkable improvement in the quality of sound. I'm going to do the back speakers in a bit too.
Old Nov 21, 2008 | 10:51 AM
Rob W.'s Avatar
Most factory speakers are just paper junk!
I must be lucky because our '08 is very quiet (except for the rear drum brake creak on one side that the dealer pretends is normal). There is one point of rattle though: the cluster/tachometer area has a very loud rattle when I hit just the right series of vibrating bumps. It usually doesn't happen, so I haven't really isolated it yet, but I swear it sounds like it's the stepper motor that drives the tach itself.
selia
Nov 29, 2006 01:39 AM
tbaleno
Events & Gatherings
15
Aug 29, 2006 05:19 AM
Jason
Hybrid & Related News
Aug 18, 2004 03:10 PM
Jason
Apr 8, 2004 03:30 PM
Jason
Mar 29, 2004 04:38 PM
