Maintenance Minder and Oil Change - Independant Mechanic vs Honda
Old Aug 15, 2007 | 12:05 PM
owlmaster08's Avatar
Default Re: Maintenance Minder and Oil Change - Independant Mechanic vs Honda
Part of me is getting itchy to put 0w-20 in my car as I've had it for 8 months now and havn't changed the original oil yet, but I'm still at 50% with 6000 miles. The other part of me is glad that I havn't had to pay for an oil change yet! I still havn't decided at which point I will go ahead and do the change. I will wait at least until 15%. I hear so many different people's opinions...
Old Aug 15, 2007 | 08:51 PM
Keep the factory fill in the car until you get to 0% or 10K miles.
The first fill is cleaning out the remainder of the foundry casting material in the block, and honing surfaces.
On your second fill switch to synthetic. The engine will get better and so will mileage if you do this.
Here is copy of the oil analysis I had done on my HCHII after its first change. There is no problem in going 10K on the initial fill oil.
Old Aug 16, 2007 | 07:40 AM
phoebeisis's Avatar
MPG FANATIC WITH GUZZLERS
Default Orient express-Values same as location average?
Orient Express,I must be mis-reading your oil analysis.It seems to show that your "elements" are Exactly the same as the location average?
I must be missing something,right?
Thanks,
Charlie
Old Aug 16, 2007 | 07:43 AM
Default Re: Orient express-Values same as location average?
Thanks,
Charlie
Since this was the first oil sample on this car the average was based on a sample of 1. As I add more sample analysis (oil changes) to this record the average will change. What is important at this time is to compare the sample results with the universal averages.
Old Aug 16, 2007 | 07:57 AM
phoebeisis's Avatar
Orient Express-thanks for the quick reply.So that is your vehicle average, or in their speak-your vehicle average at that location(unit/location).
Thanks,
Charlie
Wallace07
Aug 1, 2008 01:08 PM
lkewin
Jan 6, 2008 09:07 PM
R8Pru
Aug 23, 2007 10:22 AM
h8suvs
Dec 17, 2006 02:29 PM
mexiken
Mar 8, 2006 11:32 AM
