How do I step through XM channels using the steering wheel tuner?
Old May 13, 2008 | 01:28 PM
pagemap's Avatar
Default How do I step through XM channels using the steering wheel tuner?
Just like the subject says - "How do I step through XM channels using the steering wheel tuner?"
When I use the tuner on the steering wheel, it will step through my pre-set stations, but sometimes I want it to step through stations in order - 1,2,3,4,5,6, etc. Anyone know a way to get it to do this?
Old May 13, 2008 | 03:31 PM
Soybean's Avatar
Default Re: How do I step through XM channels using the steering wheel tuner?
Holding down the channel button on the steering wheel will advance/reverse the current channel.
It'll take 2-3 seconds each time, so it's not very convenient. When I need to surf through channels like that, I end up just reaching to the dashboard to do it.
Old May 14, 2008 | 06:24 AM
AccElan01's Avatar
I also wish there was a way to go back and forth between modes more easily. By pressing the mode button on the steering wheel you can go forward but not backward. If I want to go from XM2 to XM1 I have to press the button 5 times. Either that or press the touch screen which I try to avoid doing when possible.
camrypilot
Dec 15, 2008 12:52 PM
densand
Oct 7, 2008 08:24 PM
flopshot
Apr 29, 2008 08:35 AM
HyMinded
Jun 16, 2006 05:59 PM
