help 2008 honda civic hybrid red 12v battery and ima
Old Jul 6, 2022 | 12:02 PM
concunus's Avatar
Default Re: help 2008 honda civic hybrid red 12v battery and ima
[QUOTE=S Keith;275492]Bunu duyduğuma sevindim![/QUOTE
Hello again, my problem was solved, but I changed the 12v battery in the front today, but it does not charge. They may have installed the wrong battery. What is suitable 12v battery please help my friend
Old Jul 6, 2022 | 12:08 PM
Stock is either 151R or 151. I think it's R. The only difference between them is the terminal posts. The "R" is reversed from the other.
You can make a 51R (51) fit if you remove the shroud. It's larger and has more capacity and should last longer.
Old Jul 6, 2022 | 12:32 PM
concunus's Avatar
[QUOTE=S Keith;275495]Stok ya 151R ya da 151. Sanırım R. Aralarındaki tek fark terminal direkleri. "R" diğerinden ters çevrilir.
Örtüyü çıkarırsanız 51R (51) takabilirsiniz. Daha büyük ve daha fazla kapasiteye sahip ve daha uzun ömürlü olması gerekiyor.[/QUOTE
what should be the battery type, but does the startstop matter? Do you have any information about what technology should be?
Old Jul 6, 2022 | 12:34 PM
Lead acid.
size 151R or 51R
Old Jul 6, 2022 | 11:59 PM
concunus's Avatar
[QUOTE=S Keith;275498]Kurşun asit.
boyut 151R veya 51R[/QUOTE
really incredible. Do you think the unused battery is suitable in the picture?
Old Jul 7, 2022 | 06:36 AM
It would appear so. I can't see if the terminals are correct.
Old Jul 7, 2022 | 07:31 AM
concunus's Avatar
[QUOTE=S Keith;275500]Öyle ​​görünüyor. Terminallerin doğru olup olmadığını göremiyorum.[/QUOTE
same problem with this battery. red battery and hint light came back on. I had no problems for 2 days why did it come back? My friend
Old Nov 7, 2022 | 06:31 AM
danielmartinali's Avatar
Alih00001
Mar 8, 2019 05:23 PM
Mcguiver
Jan 6, 2018 12:40 PM
Claytonx12
Oct 22, 2017 09:55 AM
theraff
Dec 5, 2015 12:01 PM
hjb417
Apr 10, 2013 04:01 AM
