HCH at the dealer for service
Old Feb 14, 2011 | 08:34 AM
Default Re: HCH at the dealer for service
Are the lion packs compatible with the IMA system? James. When do you feel they will be available for the folks that need them? I hope I never do, but that is probably too good to be asking for. My 06 still performs like a clock and even better with the IMA up-dates. I think if I was having re-cal problems I would bit the bullet and have the pack rebuilt. I cannot imagine trying to put up with re-calibration 2 or 3 times a day . H
Old Feb 14, 2011 | 12:22 PM
Jamchel's Avatar
Veteran Mechanic
Yes they will be! Most LION and NIMH can be used interchangeably Lion would need a slightly higher initial amp hour capacity to work well with the IMA system, since even though they are higher in energy density, I don't believe they "fill" quite as fast as NIMH with charge. So to counter the higher rate of charge a larger AH battery must be used to spread the load evenly.
Other than that, yes if Re-involt's pack can deliver to spec I will definitely choose it over a remanufactured NIMH, even the honda packs are remans i hear…
Old Feb 14, 2011 | 01:25 PM
Interesting stuff if the time ever comes. I also have a 06 Prius so I would imagine this holds true for the Prius folks as well. H
Old Feb 14, 2011 | 06:04 PM
TBaFFz's Avatar
Exclamation Re: HCH at the dealer for service
Okay so I need to make a decision soon. The service manger called and gave me only one option, but he will look into a possible trade credit.
Right now the repair cost for everything is $2000. This includes new Catalytic Converter and IMA Battery Pack.
Cat Converter with Labor $1400
IMA Battery Pack $600 with Labor (He was able to get Honda to cover most of it)
I am really hesitant on spending $2000 on a 2007 with 113k miles that is still being financed. I wanted him to talk with the sales manger to possibly negotiate some sort of trade value toward a new Honda Civic/Fit, or used vehicle.
Put yourself in my shoes, what would you do???
Old Feb 14, 2011 | 09:18 PM
stevenvillatoro's Avatar
Arrow Re: HCH at the dealer for service
Just to confirm, you are not in a state with a 10-year/150K-mile warranty, correct? Any discussion with Honda's regional office about giving you a break on the cost since the IMA has relatively low mileage at 113K? I'd be making persistent phone calls, if I were you.
Old Feb 14, 2011 | 09:46 PM
Todd. By any chance did you use additive in you gas fill ups? Just wondering why the cat. failed.I have heard that additives are bad on cats? That is not a bad deal for the pack. [$600] I think I would look for a cat from a salvage or try and fool the sensor by adding a extension for the sensor unless of course the cat is plugged. It would cost you much more for a CVT or something similar!H.
Old Feb 15, 2011 | 04:49 AM
TBaFFz's Avatar
I have used Chevron Techron Fuel System Cleaner and Lucas Oil Fuel System Cleaner but have only used this maybe twice since I bought the car. I almost always fill up with Phillips66 gas.
Old Feb 15, 2011 | 04:52 AM
TBaFFz's Avatar
Well the car is still with the dealer and they want a answer asap. I need to have this figured out within the next week since my plates expire. I found couple salvage yards that sell manifold w/ cat for around $450. I am going to try and talk with the honda customer service rep about the repair costs.
Old Feb 15, 2011 | 04:56 AM
TBaFFz's Avatar
Yes that is correct. According to there warranty only residents that own the and operate in CA are able to hold that 15/150k mile warranty. I am going to call the regional rep and see what I can negotiate.
Old Feb 15, 2011 | 06:39 AM
TBaFFz's Avatar
Just talked with the service manager and negotiated $1400-1500 range. I asked him what he was charging for the Cat since I was able to find one for $672.06 at Majestic Honda
I feel that $1400 would be very fair for all of the work being done. What do you think?
