Had IMA, Check Engine, Battery Light Issue
Old Sep 16, 2019 | 08:08 PM
Mokche's Avatar
Default Re: Had IMA, Check Engine, Battery Light Issue
Originally Posted by 2007Civic4Me
I have an early build 2007 (October) HCH II. About a week ago, I had the IMA, Check Engine, Battery Light issue which has been discussed in other threads. I went to the dealership and they diagnosed the problem within an hour stating that the rotor sensor needed to be replaced. They told me that they would try a software update first to see if that would fix the problem. Apparently, that did not work because the software was already up to date.
A couple days later, I got my car back from the dealership and so far there seems to be no mechanical/electrical problems but I have noticed the following:
1) There is a low volume high pitch whirring sound whenever I accelerate
2) My FE seems to have taken a 3-5 mpg hit where the IMA does not seem to kick in as readily and therefore the ICE has to work harder
Has anyone else with this problem experienced anything similar?
Thanks in advance.
Mine had same problem, whirring if from worn bearing of ac compressor, had it replaced and symptoms disappeared.
Old Sep 16, 2019 | 08:21 PM
Thank you SO MUCH for replying to a TWELVE YEAR OLD THREAD with likely bad information.
RockMonkey
Oct 22, 2016 08:35 PM
chunkadelic
Jan 25, 2014 02:48 AM
slider162
Oct 27, 2011 11:07 AM
SidewinderX
Mar 4, 2011 06:49 PM
dblee50
Oct 27, 2009 07:28 PM
