Grid charger prolong
Old Jan 28, 2017 | 02:35 PM
  #31
Default Re: Grid charger prolong
I can't advise you. Without tap voltages, it's 50/50. Since they don't clearly indicate a cell failure, it's better than 50%. That's all I can say.
The only danger is the reduced power and the eventual deterioration of the battery to the point that the car will no longer charge the 12V.
Old Jan 28, 2017 | 04:32 PM
  #32
fanfaron's Avatar
I thought it was the tap voltage we did...
is tap voltage a measure directly from the subpack?
Old Jan 28, 2017 | 04:36 PM
  #33
You just measured the 11 tap voltages - where the BCM "taps" the pack to monitor subpack voltages.
Old Jan 30, 2017 | 10:33 AM
  #34
fanfaron's Avatar
Hi mr. Keith forgot to mention that the code error that dealer gave me is DTC P0A7F, If this can be any help....
Another question Mr. Keith,
on this post the operator mention the dealer has to reprogram the car when the battery is changed..
https://www.greenhybrid.com/forums/f...battery-27998/
I thought it's plug and play thing. Why this guy says it needs to be reprogram?
sorry for the trouble.
Old Feb 3, 2017 | 08:32 AM
  #35
fanfaron's Avatar
The check engine light and the ima went off for two days now. Wonder what that means? Recals are still very frequent.
I start to really hate that car...
Old Feb 3, 2017 | 08:45 AM
  #36
Nothing has changed. Your battery has failed. You are just seeing differing responses to that failure. It could be temperature related, a change in driving conditions/style, etc.
The fact that you're having frequent recals and likely seeing reduced mileage are confirmation.
The car is continuing to behave in a manner consistent with a major system failure. If your increasing hatred of the car is because you are expecting it to "heal" or fix itself, I can promise you, it's only going to get worse.
Eventually, 12V charging will become unreliable - it might be a day, or it might be a year.
spare yourself the frustration:
1) sell it
2) scrap it
3) fix it
Continuing to ignore it is just going to keep a frustrating condition in your life.
Jamchel
Sep 21, 2018 05:41 PM
sfenwick76
Mar 25, 2017 03:48 PM
pmaster88
Toyota Highlander Hybrid
May 30, 2015 08:00 AM
navguy12
Jan 14, 2012 01:53 PM
