Grid Charger Build
Old Jul 9, 2018 | 07:32 PM
jimmyf's Avatar
Default Re: Grid Charger Build
That sounds simple enough.
I understand the importance of cooling and will definitely do that on the bench. If I do attempt in car charging, I understand I will need to short the PWM wire (light blue) to negative (black) in the IMA fan harness and of course supply it with 12 volts. Can you confirm that?
I'm waiting for this hot weather to cool off though before I do anything further.
Old Jul 9, 2018 | 07:41 PM
Yes. 12V/10A
If you pull the pack and bring it inside, temps are a non-issue.
Old Jul 12, 2018 | 03:47 PM
jimmyf's Avatar
Thank you very much for your help.
misterwilling
Jan 12, 2019 01:13 PM
fanfaron
Feb 3, 2017 08:45 AM
The Great Gazoo
Oct 3, 2014 04:28 PM
