Great weather = great FE!
Old May 1, 2007 | 09:42 AM
noflash's Avatar
Default Great weather = great FE!
Spring finally came back again!
After averaging 40-42 since fall, this weekend we hit over 50 in both cars. This morning I got 62 on the way to work.
Finally!
So jealous of you socal guys...
Old May 1, 2007 | 03:57 PM
Jess's Avatar
Default Re: Great weather = great FE!
Same here. After a season of mid to high 40mpgs, now were getting high 50's to low 60mpgs. Gotta love it. Just keep that AC off.
Take Care
Jess
Old May 2, 2007 | 07:42 AM
noflash's Avatar
I'm using "AUTO" set at 75 and I think the dealership even put my tire pressure back to factory spec.
Old May 2, 2007 | 12:34 PM
rgx's Avatar
rgx
I have seen the same thing too, and the difference is bigger than expected. Even smaller steps in temperature makes big difference in FE. I am more and more convinced that it has to do with the strategy of the engine management. At 10 deg C the car is less prone to shut off the engine when coasting. Going downhill at around 70 km/h the instant FE display will show a few bars (around 2 L/100 km), sometimes together with one or two bars of regen, unless you let go off the pedal completely. At 20 deg C the engine shuts down long before you release the pedal completely. Also in the warmup phase there is difference. At 20 deg C auto-stop is enabled more or less directly from start (cold engine), but at 10 deg C the engine has to reach almost full temperature first. I guess this strategy is primarily to get heat for the climate control (and not so much to reduce wear on the engine).
My own estimate is that FE is 10% better at 20 C than at 10 C, also for longer trips. I haven't done any serious testing or measurement, though.
Old May 2, 2007 | 12:50 PM
Your engine shuts down when coasting down a hill at 70 km/h?, actually AS. How about at 90 km/h? I have never expearanced this, something to look forwad to.
Old May 2, 2007 | 02:39 PM
Jess's Avatar
I think when rgx says "shut down" he means the valves are closed, so that the engine is not firing=using gas.
Jess
Old May 2, 2007 | 03:24 PM
Shoot, I thought we may be going back to the free wheel days!! Thanks Jess.
UTAlumnus
May 22, 2010 09:57 AM
GEJehle
Jul 19, 2005 07:14 AM
sdctcher
Jan 12, 2005 12:30 PM
xcel
Jun 16, 2004 11:33 AM
