Goodyear Assurance Fuel Max tires?
Old Nov 5, 2009 | 02:28 PM
  #61
Dustman's Avatar
Default Re: Goodyear Assurance Fuel Max tires?
I have 4,500 miles on the GY FuelMax tires.
My FE has not returned to normal, still about 40-41MPG vs 44-45.
I can notice significant "resistence" to keep rolling and increase the gren bars when I let off the gas.
I put PSI up to 44 at all 4 corners. Max PSI is 51 HEATED, so going much beyond 44 is risky and potentially reduces tire life considerably (center tread wear out).
Needless to say I am not pleased about FE.
I used to see periods of driving at 50-60MPG, but since the new tires I have never seen that range again.
Handling, grip, confidence all greatly improved though. Huge noise reduction too.
If you can live with lower FE, then these are good tires for the benefits above.
Old Nov 6, 2009 | 08:01 AM
  #62
Next time get Michelin Pilot Exhalto tires. My mileage has been up 10% after installing them over 30K miles ago, and they have only used up half the tread.
Old Nov 6, 2009 | 06:49 PM
  #63
Greg's Avatar
Hypermiler wanna Be
I ran my OEM Dunlops at the max pressure for that tire (44psi) most of the time and never had a problem. They wore "evenly" as far as I could tell. I will have to check tire pressure after driving on them for a while I guess to see. I pushed mine to 47 psi today to see how that affects FE.
I have had my GY FuelMax tires on for a couple of weeks now, and I would say that my mileage has dropped off some. ..but better than the ComfortTreads I put on there first.
I think you summed it up very well...much better grip, lower noise, but unfortunately with a bit lower FE. Maybe it will get better as they wear.
Old Nov 24, 2009 | 08:23 AM
  #64
ndabunka's Avatar
Originally Posted by bigdog9586
I have the GY Triple Treads on my HHR and have been very happy with them for 20K and 2 winters. Go good in the snow and look like brand new. Rated for 80K on wear so we'll see.
The GY Triple Treds are rated for 60K miles, aren't they? I ask because I bought a set of these for our Highlander Hybrid and they appear to be wearing prematurely (about 28K miles now and one is done. The other three look to have about another 5K left on them). Before you ask, yes, we do rotate and align regularly.
Update - GY replaced the Triple Treds with the Fuel Max. They gave us $80/tire towards the new ones so at least that lowered the cost to "reasonable". $274 later we have the new tires on it and will see how it goes from here. There is NO WAY FE can be any less than the Fortera's. The prior Integrity's provided 26MPG. The Fortera's were basically 25MPG. We are hoping the Fuel Max will get us back over 26MPG once again.
Old Nov 24, 2009 | 09:41 AM
  #65
vincep5's Avatar
I bought a set of 4 Fuel Max last week. Will get them installed this week or next. I'll update on my gas mileage after a week.
Old Dec 3, 2009 | 09:55 AM
  #66
vincep5's Avatar
Ive had the tires for 3 days now, Im noticing a much smoother and QUIETER ride than my OEM Michelins. Too difficult to determine the MPG hit. I am noticing that my rpms are slightly higher than usual. Instead of 1200 they up near 1400 when i reach slower cruising speeds under 40mph. Im still able to get my iMPG meter in the 60-70 range.
Seems like there is more of an effort to keep speed. but thats the tradeoff. better traction is worth it.
Old Dec 3, 2009 | 12:23 PM
  #67
Mendel Leisk's Avatar
Thanks for the update. You know, considering the the TireRack review, and the various testimonials such as yours, I'd say Goodyear's name choice for this tire borders on deception. It has so-so rolling resistance, not bad, but not terrific, and not as good as some run-of-mill OEM's.
Old Dec 8, 2009 | 02:30 PM
  #68
ndabunka's Avatar
These Assurance Fuel Max tires performed well in the snow (about 6 inches) on our 06 Highlander Hybrid during a recent ski trip. The sidewalls are quite soft however and require a bit more "attention" when taking those big mountain curves (dry on the way up and snow on the way back 4 days later).
Old Dec 11, 2009 | 11:36 AM
  #69
dhill's Avatar
The Nov edition of Consumer Reports gave a relatively low rating for the Assurance Fuel Max. It scored high on low rolling resistant but received a negative rating on tread wear. Michelin Primacy MXV4 received the highest score in the same category as the Fuel Max with an excellent rating in tread wear and a higher than average rating for rolling resistance.
Originally Posted by basher
Looks like these tires have just been released by Goodyear. My local tire place can order them now for $109 (CDN) installed and balanced.
Has anyone read anything about these tires? I am thinking about trying these out.
http://www.moderntiredealer.com/News...-Max-tire.aspx
"February 03, 2009
Goodyear introduces Assurance Fuel Max tire
Goodyear Tire & Rubber Co. introduced its Assurance Fuel Max all-season tire at its 2009 Dealer Meeting in Washington, D.C., earlier this week.
Compared to the original Assurance tire, Assurance Fuel Max provides 27% less rolling resistance.
"In response to today's economic environment and fluctuating gas prices, drivers everywhere are trying to use less gas. It's all part of a larger consumer trend toward spending money more wisely," says Joey Viselli, Goodyear brand director. "With the new Assurance Fuel Max, Goodyear is offering a fuel-efficient solution, but with great wet and dry traction."
Assurance Fuel Max is engineered with the following features:
* a "Wet Tread Zone" with dual AquaChannel grooves that help evacuate water.
* zig-zagging "micro grooves" and center tread notches for grip in rain or light snow.
* a "Dry Zone" that, with the help of strong shoulder blocks, is designed to enhance handling and grip on dry pavement.
Several sizes of the Goodyear Assurance Fuel Max are shipping now. By April, all 27 sizes, which will cover about 80% of the auto tire segment, will be available for models such as the Pontiac Grand Prix and Chevrolet Impala, minivans such as the Chrysler Town & Country, and hybrids such as the Toyota Prius and Chevrolet Malibu.
For more information on Goodyear's products, visit www.goodyeartires.com."
Old Dec 13, 2009 | 06:18 PM
  #70
GardenWeasel's Avatar
Kind of a follow up from my previous post where I commented I was running 50 psi, I've lowered my pressure to 41 front and 37 rear. Not much difference in FE for me in this weather...but more comfy for my wife (and me too, if truth be told!). Cruising gently around town I am getting 45 to 47 mpg. Haven't taken any trips since temps have dropped. Tires are certainly not for the folks trying to squeeze every mile possible from a gallon of gas, but they are certainly better than OE and are satisfying me. I have 'bout 9000 miles on mine now.
