Fuel display vs actual
Old Aug 20, 2006 | 11:17 AM
rgx's Avatar
rgx
Default Fuel display vs actual
I know this has been discussed before, in various threads, just couldn't find any dedicated thread about it now.
My overall fuel consumption after 5800 km is 5.03 L/100 km (46.8 mpgUS), but the display average has been 5.24 (44.9). While rewarding to find you actually spend less than anticipated, a 4% error is a bit too much, I think.
I have seen others comment about a 2 mpg difference, which is about what I get. Please post your figures, so we can compare.
Old Aug 20, 2006 | 12:11 PM
Anahymbrid's Avatar
Default Re: Fuel display vs actual
Mine is ALWAYS off 1.6 to 2.1 mpg.
Old Aug 20, 2006 | 12:32 PM
Mr. Kite's Avatar
Here are a few of the threads.
Calculated MPG 1.4 higher than dash
Calculated Mileage differers from Actual?
My lifetime fuel economy is now only 0.8mpg (1.5%) more than the display.
Old Aug 20, 2006 | 03:44 PM
kenny's Avatar
The display on my 2006 HCH averages 1.4 MPG lower than what I calculate at the pump.
Old Aug 20, 2006 | 04:22 PM
JordanCS's Avatar
I'm always between .6 (lowest) to 1.8 (highest) below the actual on my displayed FE. The biggest discrepancy was on my most recent tank, which was almost all highway. The car showed 48.0 MPG, while the actual was 49.8 MPG. That difference leads me to believe the major leg of that (which showed 49.5 MPG) was really closer to 51. FTR, I was driving on very hilly terrain in western PA and WV going 68. Not bad.
Meggert's Avatar
My displayed mpg is between 1.2 and 1.4 mpg less than calculated on fill ups.
Mark
Old Aug 21, 2006 | 08:47 AM
ShawnS's Avatar
Enjoying my hybrid
My displayed mpg has been 2-2.5 lower than calculated.
Old Aug 21, 2006 | 09:25 AM
EZ2beGreen's Avatar
My calculated mileage has always been approx .8 to 1.5MPG better than the display.
My experience with other (non-honda) automobiles has always been that the display is higher than actual, with sometimes significant differences.
Both the HCH & the Odyssey actually read slightly lower than calculated at the pump, which is always a pleasant surprise. The variance on my Honda's has never exceeded 4% (always higher than the display).
Old Aug 21, 2006 | 09:56 AM
cherokee180c's Avatar
My first two tanks read 1.1 and 1.2 mpg lower than actual at 43 and 44 mpg calculated. My last tank read almost 2.0 mpg lower than actual at 48.5mpg calculated. The last tank was 4.5 mpg better than my second tank as the car is just breaking in. This leads me to wonder if the mpg display may be over estimating the fuel usuage during the lowest amount of fuel flow, which would correspond to when you are getting the most mpg. Does anybody else notice a bigger difference on their highest mpg tanks?
Old Aug 21, 2006 | 10:09 AM
FourSticks's Avatar
On four tanks of gas so far the actual is been consistently 2% above the display. My lifetime caluclated is at 54.4 mpg. The car display is at 53.3 mpg. Each tank has been 2% (plus a miniscule amount) over the car display value.
Mike
