Firewall access for 12 batt access?
Old Apr 20, 2008 | 08:29 AM
Default Re: Firewall access for 12 batt access?
The empty slots on the bottom row are all hot. Use a circuit tester to determine which ones are switched and unswitched. I believe that 5 is unswitched and 7 and 8 are switched.
Old Apr 20, 2008 | 11:39 AM
holicow's Avatar
Thanks, I'll double-check with my tester, just thought I'd get a head-start (and be a little lazy in the process.).
Old Apr 21, 2008 | 05:47 PM
holicow's Avatar
Ok, this is getting ridiculous. Is there a specific Honda add-a-circuit? The fuses will not fit in the add-a-circuit dongle I got, although it fits fine in the slot in the fuse box.
The car fuses now have the extra-teeny legs that will not fit in the separate slots.
Funny thing is that I get no power from the add-a-circuit when it is in an empty powered slot, so that tells me there must be a special connector, right?
Old Apr 21, 2008 | 06:00 PM
The Honda mini-fuses are a little bit different from a standard mini-fuse, but are interchangeable. Just go get some standard mini-fuses of the correct amperage for your setup.
The reason that you may not be getting any power to the add-a-fuse circuit is that you have it plugged in upside down. Try turning it around. (now think about why this is so...)
Old Apr 22, 2008 | 09:14 AM
giantquesadilla's Avatar
So I can put a standard minifuse in my HCH?? I didn't know that.
Old Apr 22, 2008 | 09:26 AM
yes. They don't push all the way flush in like the Honda mini-fuses, but still work just fine.
Old Apr 22, 2008 | 07:13 PM
Thanks for that! I didn't know where I was going to get those stupid Honda fuses. God forbid I would have to go to the dealership!
raidfibre
Feb 4, 2012 07:57 AM
Melvinsaniac
Sep 30, 2011 04:24 PM
08hybridok
Sep 20, 2007 07:52 PM
feinstei
Jun 11, 2006 06:05 PM
