fe meter when accelerating
Yep, I would say it is normal especially when the vehicle is still warming up.
Again, don't be too depressed about this behavior as it occurs in every car (hybrid or not). Of course the key then is to ease into to your cruising speed and then let the FE indicate a much better reading. Constant and steady gas pedal pressure is best. Fluctuations in accelleration is not... after all, FE is a "game" of averages.
Cheers;
MSantos
Cheers;
MSantos
Cheers;
MSantos
Cheers;
MSantos
I think the IMA is there to help get you too speed, with-out holding the traffic up? I guess its not terrible to hold up traffic, trucks do it all the time!!! I don't know why they don't put the trucks on a grave yard shift? Off the roads by six am !!! OK back to the subject, Once you are at speed , feather it for good FE. Hopefully you come to a hill that allows regen so you get the IMA recharged for the next boost. Or you could Pg for regen? That's my opinion. H
![Tongue](https://electricvehicleforums.com/forums/images/smilies/emotikons/tongue.gif)
Yes, it's normal.
When up to speed and then at a constant speed on level ground (hopefully UNDER 70 MPH!), you should see it back near the middle (50 MPG) or so.
What's your overall MPG? I'm at 46+.
sonyah
10-13-2006 03:00 PM
