Everything you need to know to DIY a CVT fluid Change
Old Mar 4, 2009 | 06:46 PM
Default Re: Everything you need to know to DIY a CVT fluid Change
So was my last change. I let the transmission drain for a long time to get as much as I can out of the torque converter, and it was 3/3 spot on.
Old Mar 6, 2009 | 05:11 PM
atikovi's Avatar
This ain't rocket science.
Before:
10 minutes after:
My 06 for sale: http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
Old Mar 4, 2010 | 09:10 AM
dwichman's Avatar
In a few threads I've read others replacing the cvt fluid 3 times, running the car between each, to attempt to replace the majority of all 5 quarts. Is the MM assuming a full flush when it tells you to replace cvt fluid, or only a single 3 quart change? Which to do?
I prefer only doing it once if that's okay.
Old Mar 4, 2010 | 09:26 AM
Jaba
Only use three quarts . The three times change is for when you have issue's with the CVT. Jerky or what-ever. Hal
Old Mar 9, 2010 | 02:42 PM
iridium130m's Avatar
umm, there's no torque converter on a CVT tranny, only a clutch pack.
and yes, i only filled mine through the dipstick plug. walk into auto parts store and ask for a tranny funnel....its an easy fill.
Old Dec 22, 2014 | 08:28 AM
Aralyn Rogers's Avatar
how many quarts of oil does a 2004 Saturn Ion 2.2 liter Ecotec takeI haven't really had any transmission problems but I wanted to do a soft flush so I drained out one and a half quarts and replaced one and a half quarts is this okay and I just added the Valvoline full synthetic CVT transmission fluid
Old Feb 3, 2015 | 09:54 AM
  #27
klcl's Avatar
This is the simple calculation:
After 1 drain and refill 3 qt drained 2.4 qt left means 3/5.4= 56% of fluid was drained.
After 2nd drain and fill 56% of the remaining 2.4 qt of old fluid is replaced = 1.3 qt which means 4.3/5.4 approx = 80% of original fluid is now replaced.
After 3rd drain and fill 56% of the remaining 1.1 qt old fluid is replaced = .62 qt which means approx 4.92/5.4 = 91% of original fluid is now replaced.
So it seems a second drain and fill might be worth it to get 80% fluid out but in my opinion a 3rd drain and fill to get to 91% is probably not worth it.
Old Feb 3, 2015 | 06:05 PM
  #28
Easy mode:
Change 3 qts (1 drain/fill) every other oil change (about 15K miles).
07civichybrid
Sep 15, 2018 06:17 PM
dwichman
Aug 19, 2009 06:58 AM
UWAdventurer
Nov 30, 2008 04:28 PM
atikovi
Dec 22, 2006 11:40 AM
nbalthaser
Mar 26, 2006 03:08 PM
