DVD Navigation is broken?
Old Aug 24, 2008 | 01:25 PM
  #31
JetfireK's Avatar
Default Re: DVD Navigation is broken?
There is a way to open the Navigation and reset it...Look in your manual if you do not hav one then look on line at the Navigation system manufacturer...ALL GPS...RESET....
Old Aug 25, 2008 | 08:44 AM
  #32
nark's Avatar
Thanks a lot Caholla, that was a lot of very useful information. It helps put my mind at ease somewhat. So when they replace the navi, does the original warranty still apply or is there a new 3 yr/36k warranty on it? If the former, if they replace it at 35,999 miles and I drive it out of the shop and it breaks again, I would need to fork over the money to replace it again right?
JetFireK: Not sure what you mean, why would I want to reset the navi?
Old Aug 25, 2008 | 11:01 AM
  #33
caholla's Avatar
Hybrid Owner
Replacement parts have a balance of factory warranty or 1 yr - 12000 mile warranty, whichever is greater.
JetfireK's message is a head scratcher. I still haven't figured it out...
Old Aug 26, 2008 | 07:23 AM
  #34
JetfireK's Avatar
Resetting your GPS if it quits working....I have a Garmin Nuvi 880, grandson has a Garmin (whatever) these are Portable
If the GPS stops working turn it off and on again.
If the problem persists:
Slide the power key to the left and hold it there for 8 seconds.
It should then operate normally.
You can also remove and reinstall the battery to reset the Nuvi GPS
Also do this. To have on hand.
If your GPS did not come with an operators manual
Go on the internet, print the manual,
Take it to Kinkos or Office Depot and have them size it down bind it with a nice cover. I think its 12 dollars...and YOUR SPECIFIC MANUAL WILL TELL YOU HOW TO RESET YOUR GPS.
THEY DO NOT BREAK......THEY JUST NEED RESETTING..
AND FINALLY...I am still waiting for my Sport 2door HB to arrive in Port....
Old Aug 26, 2008 | 10:44 AM
  #35
caholla's Avatar
Hybrid Owner
Your suggestion has nothing to do with the factory installed DVD Navigation system...and nothing to do with the problems covered in this thread...
Old Aug 26, 2008 | 11:03 AM
  #36
zeta_msz_006's Avatar
I am guessing jetfireK does not realize that the factory GPSs are disc based and not memory based, like the handheld Garmins he is talking about.
Old Aug 26, 2008 | 02:12 PM
  #37
nark's Avatar
Caholla: Thanks for your help so far. I still need to take my car back because they did a darn shitty job at installing the new nav. Its sticking out about an inch from the dash.
Old Aug 26, 2008 | 03:54 PM
  #38
caholla's Avatar
Hybrid Owner
Not excusing the workmanship, but I'm willing to wager that this was probably the first Civic unit your technician has installed. It should be an easy enough fix (once the dash comes apart again LOL).
Old Mar 26, 2009 | 06:31 PM
  #39
bar10dah's Avatar
I found the TSB that covers this problem with the Navi unit scratching the DVD. I think it was a CR-V forum that I found it in. Hope it helps.
http://www.in.honda.com/Rjanisis/pubs/SB/A08-051.PDF
ahmadkq
Nov 4, 2013 01:18 AM
jhfarr73
Mar 10, 2007 03:25 AM
Jay_Taipei
Lexus RX 400h
Jun 16, 2006 11:00 PM
bdtang
Oct 2, 2005 04:17 PM
ericbecky
Honda Insight
Jun 3, 2005 02:21 PM
