CVT jerky
Old Jul 28, 2015 | 10:24 AM
Default Re: CVT jerky
Ah. You are far more capable in that area than I am. Here you go:
https://www.mouser.com/ProjectManage...6-8143eb56731e
2X 28-100V LED power supplies in series for pack (constant current 350mA, voltage will rise as battery charges)
1X 12V PS for fan power
Board on which to mount
Search "HCH1 fan control" on insightcentral.net. Peter Perkins (retepsnikrep) has a wiring diagram for a PWM controller design. I believe it will work for the HCH2 except the PWM signal is inverted, so the pot adjustment will work in reverse.
There is also an option on eBay for $50. I don't know if it works, but it's a relatively cheap option if your time is more valuable than what you might save DIY.
Good luck,
Steve
Dane Mclean
Jan 27, 2013 12:15 PM
jonmatt4nr
Jun 15, 2006 10:08 AM
traderfjp
May 15, 2006 09:13 PM
Verio
May 11, 2006 04:09 PM
ftlum
Mar 27, 2006 06:07 PM
