Can the climate control be switched from Celsius to Fahrenheit?
Old Jul 9, 2008 | 05:11 AM
mhaven98's Avatar
Default Can the climate control be switched from Celsius to Fahrenheit?
I had a look through the forum and did some searching but could not find this information. I know I can change the odometer, speedometer, etc from metric to imperial or vice versa. However when I change it, the climate control still shows the temperature in Celsius. I was wondering if there is a way to switch it to display in Fahrenheit as I have always preferred that when it comes to temperature.
Any info would be appreciated.
Old Jul 10, 2008 | 11:46 AM
yangsta's Avatar
Default Re: Can the climate control be switched from Celsius to Fahrenheit?
This is mostly my best guess:
Your HCH was configured for your region. For example, the climate control display for HCH sold in the U.S. is in Fahrenheit. There is likely a way that a dealer or electrician can switch over the setting, but as far as I know there isn't a C/F switch available to the consumer.
Old Jul 10, 2008 | 12:37 PM
mhaven98's Avatar
Thanks for the response.
It would seem that it is indeed not an easy switch. I just thought that since the speedometer and odometer, etc could be changed so easily, why wouldn't the climate display? It's not a big deal I was just hoping that it could be done.
Sphinx88
May 8, 2011 08:44 AM
skata
May 2, 2008 12:13 PM
biglakerider
Jan 19, 2006 09:12 PM
lkewin
Oct 7, 2005 08:01 PM
tbaleno
Mar 24, 2005 12:06 PM
