battery pack capacity - grid charging
Old Aug 2, 2022 | 12:55 PM
gabr777's Avatar
Default battery pack capacity - grid charging
Hi,
I'm in the process of grid charging -> deep discharging -> grid charging and want to share my data and see if you have something similar available to compare.
I found these 2 reports, which are showing roughly the same results as I'm getting.
2006 Honda Civic-8725 Hybrid Battery Test Results
https://avt.inl.gov › default › files › pdf › hev › b...
2006 Honda Civic-9329 Hybrid Battery Test Results
This battery pack was once replaced by Honda 8yrs ago and did just 60k kms since.
I've built a grid charger/discharger and I'm doing this through a built-in harness in the car.
The reason I started the whole process is that I observed during summer when AC is on and engine is auto stopped battery SOC goes down to 4 bars much sooner than few years back and quickly drops to 2 right after followed by the engine being started with disabled IMA for a while and starts to recharge the battery, as long as it reaches full SOC. Same happens on a highway after 1 or 2 hard acceleration. No errors though.
What I see is I could roughly get over 5000mAh out of the batteries. But still feels worse over the years.
Below table shows what I got during discharge.
I still need to get the car going and see if it got any better..
Any comments are appreciated.
gabr777
Jun 29, 2022 02:48 AM
inzar
May 7, 2021 11:38 AM
Amjadov
Jul 16, 2020 06:57 PM
paulk
Jan 25, 2018 03:58 PM
jwillvin
Oct 4, 2017 08:13 AM
